12-05-2019, 11:44 AM
Slide/stabilizers don’t work
I have a 2018 27DBK with electric stabilizers on it. The front and the back stabilizers both have their own switches on the outside, and the slide has a switch on the inside panel, next to the awning switch. My slide and stabilizers do not work with their switches, but the awning does. Everything works when I use the wireless remote for the unit. I’ve went through fuses and didn’t see any blown. I’m wondering if anyone has any suggestions or has seen this before and could point me in the right direction.
12-05-2019, 02:08 PM
Do you know where the remote receiver is located? Check all the fuses on it.
Do you know where the resettable breakers (fuses) are located near the front of the RV?
It could be one of those tripped and needs resetting.
Gotta go campin!
12-05-2019, 02:39 PM
I have a main breaker box with fuses, I checked all of those. I have another set of fuses under fridge I’ve checked, all good. I’ve found two inline fuses both good. And the resettable breakers seemed good up front and I actually replaced one of them. I have one more removable panel on my bathtub I was considering taking off to check for fuses under there but it seems like a weird spot for there to be fuses.
12-05-2019, 03:10 PM
Guessing you lost a power leg that feeds those switches.
12-05-2019, 03:19 PM
What exactly is that
12-05-2019, 03:36 PM
They put the remote receivers in some odd places.
I don't have a Sabre listed in my spreadsheet, but there several units with the receiver under the bath vanity.
Gotta go campin!
12-05-2019, 03:43 PM
It’s a Salem
12-05-2019, 03:54 PM
It sure sounds as if the feed circuit for the items you mentioned doesn't have power.
On units with remote pendants for those items, the feed to the switches typically comes from the remote receiver/relay assembly.
I wish I could tell you where it is on your particular model but I can't... but you are going to have to locate it.
Have you contacted Salem?
12-05-2019, 04:44 PM
I haven’t contacted Salem, I contacted the dealer and of course they just want me to bring it in. I believe the assembly is the one under my fridge because it clicks when I use the remote.
12-05-2019, 05:09 PM
I don't have a 27DBK listed, but the 27RKSS 2018 models have the remote receiver located Under the "Bathroom Sink Behind Access Panel". In fact several Salem models have it listed as being there.
I have a 2018 33BHOK as being under the fridge.
When you do find it please let us know and I'll add it to the spreadsheet.
Gotta go campin!
12-05-2019, 05:36 PM
I plan to work on it Saturday. I will get back to you with pictures and if I find anything. Thanks for the continued help.
12-31-2019, 02:48 PM
12-31-2019, 05:17 PM
Did you ever find the problem?
12-31-2019, 06:21 PM
I have not. Scratching my head as to where anymore fuse locations would be. No replies from forest river, which is incredibly disappointing considering I just bought a cedar creek and just want to get this one fixed and sold.
12-31-2019, 06:24 PM
I have the same system, the way they installed.... Things I can see having hard to find problem s
12-31-2019, 06:27 PM
Here is my location
12-31-2019, 06:30 PM
Thats a different fuse panel than the ones I posted? So there’s really 3 fuse locations then? I don’t think I can get to the right side of my water heater like that.
01-04-2020, 08:26 AM
Do you know where the resettable breakers (fuses) are located near the front of the RV? It could be one of those tripped and needs resetting.
I did not see a response to this question? This is what they look like. There are usually 2 or more and are usually located near the battery. If they are exposed to the weather, they are subject to corrosion. Some are automatic and some are manual reset.
I would also check all the connections to the ground bar(s). There may be more than one.
01-04-2020, 09:53 AM
There are 2 of them near the front of the unit by the battery. One had looked like it was tripped, and I replaced it with an auto resettable one and it didn’t solve the problem. The other had a ton of wiring coming to it and looked like it wasn’t tripped. My question is why would these be an issue if I’m connected to shore power. Excuse my lack of knowledge here as the answer is probably obvious. And would a ground connection loose somewhere cause two things to stop working with buttons but not remotes?
01-04-2020, 12:32 PM
I don't have a definitive answer for you. My guess is it would depend on how the feed from the converter is wired into the 12 volt system. I am not an electrician, but over the years I have experienced some strange issues with 12V RV systems. Most of them that involved only some appliances/powered devices have been related to the circuit breakers and grounding. I have never had an RV with remote control so no experience there.
