Old 08-08-2011, 05:42 PM   #1
Jsr9878's Avatar
Slideout fuse
Ny body know where the slideout fuse is on a 2008 Salem 27 bkhs ?
Jsr9878 is offline   Reply With Quote
Old 08-08-2011, 09:01 PM   #2
Can't tell you for sure, but most slide outs have a breaker, on the frame, behind the trailer tongue. Follow the positive battery lead, it will lead to a breaker, then jump over to another breaker. One of the breakers feeds the converter, the other one feeds the slideout. Some have a very small, reset button, usually on one end of them. Hope it helps. You will have to crawl under the trailer, and for less than $20.00, you can buy one that has the auto reset function. If I had one, I would replace it.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-09-2011, 10:44 AM   #3
Jsr9878's Avatar
Yes I did see the breaker under the front, didn't notice a reset button. It was also 95 deg and 97% humidity when the problem came about! I will have to double check it. Thanks!!
