Old 07-26-2015, 07:41 AM   #11
kdot's Avatar
Stabilizer Jacks
Tmas, you said you had "x chicks." I'm jealous; I wish I had that many.
Kdot
2017 RPod179
2016 Honda Pilot
kdot is offline   Reply With Quote
Old 07-27-2015, 04:10 PM   #12
Does anyone have experience with BAL lock Arms?
BAL Lock-Arm Stabilizing Bar - BAL 23216 - Stabilizing Jacks - Camping World
2009 Chevy Silverado 5.3L Z71
2014 Salem 281QB
tmas is offline   Reply With Quote
Old 07-27-2015, 04:19 PM   #13
Georgia Frog Rally 2018
aceinspp's Avatar
You should also use block under the jack pads. The less distance that you have to lower you jacks gives you more stability. I use the plastic pads and sure helps. I get some movement. but to me Iam not bothered by it. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 08-24-2015, 03:33 PM   #14
MartiB's Avatar
I use wood blocks under mine and then lower the jacks until they seem firmly on the wood. I also have 4 chocks - two on each side that sit between the tires - sort of the same effect as the X-chock I guess. I don't seem to notice much movement unless the jacks aren't firmly down.
MartiB is offline   Reply With Quote
Old 08-24-2015, 03:41 PM   #15
rattleNsmoke's Avatar
Kdot
Is that like having 72 virgins??...
rattleNsmoke is offline   Reply With Quote
jacks
