Old 11-22-2015, 09:22 AM   #1
Stabilizer jacks not working
I have a 2015 Salem 27 RKSS. My stabilizers both front and back are not working. That being said they are both down. So right now I cant take it anywhere to be looked at. I checked for fuses at the motors, none that I can see. Found one up front near the battery, that one is going to the tongue jack and it works. No fuses blown in the panel area. Getting real frustrated. AND of course there is no manual in the packet that was given to us when we purchased it. I do have 3 more weeks on the 1 year warrenty. But I need them up now. Any help would be appreciated.
Tank99 is offline   Reply With Quote
Old 11-22-2015, 09:23 AM   #2
Is there a way to buy pass the motor?
TT-2015 Salem 27RKSS
TV-2013 Toyota Tundra
Days Camping
'14-7
'15-28
Old 11-22-2015, 09:37 AM   #3
fonzie's Avatar
Fuse for power stabilizers are usually in the distribution panel eg: 20 amp show below PSJ....need to take fuse out to visiually check if burnt open.....don't rely on red led...
Fonzie
Old 11-22-2015, 09:42 AM   #4
fonzie's Avatar
If you have LCI electric stabilizer, then you can manually raise them.
Fonzie
Old 11-22-2015, 09:44 AM   #5
Fonzie, I'll check again. Do you think it would be tied on with something else? There is nothing labeled jacks or slides. In your picture where it is labeled PSI and HHI, mine is empty. No fuses and not labels.
Days Camping
'14-7
'15-28
Old 11-22-2015, 09:48 AM   #6
fonzie's Avatar
Yes it could be tied with something else. Have someone press the raise switch outside and see if a red led lights up ( = burnt fuse) at the panel. Also there could be a fuse underneath trailer near tongue.
Fonzie
Old 11-22-2015, 09:49 AM   #7
Thanks for the manual, thats the one I have.
Days Camping
'14-7
'15-28
Old 11-22-2015, 09:50 AM   #8
Pull and Check/Replace like Fonzie said! Youroo!! Or use supplied Crank!
youroo is online now   Reply With Quote
Old 11-22-2015, 09:52 AM   #9
Thanks for your help. I will give an update later.
Days Camping
'14-7
'15-28
Old 11-22-2015, 09:57 AM   #10
fonzie's Avatar
Also if you have a battery disconnect, make sure it is "on".
Fonzie
jacks
