Old 08-17-2016, 09:24 PM   #1
Stabilizing Jacks
Have a 22' Salem TT. My stabilizing jacks are in the four corners. Still some rocking, so says DW. I have read that many people put the rear jacks just to the rear of the axel. Is there optimum placement of the jacks for stabilization?
Peter is offline   Reply With Quote
Old 08-17-2016, 11:03 PM   #2
I added two more jacks in the middle of my camper
Sent from my LG-H740 using Tapatalk
2008 v-lite 30 wrls
gsbuick65 is offline   Reply With Quote
Old 08-18-2016, 12:09 AM   #3
What I really wanted to know, "do people feel they get better stabilization by putting the rear stabilizing jacks closer to the rearmost axle as opposed to putting them close to the rear frame corners"?
Old 08-18-2016, 04:37 PM   #4
Golfnbike13's Avatar
What are you people doing, having dance parties inside your trailer?
Golfnbike13 is offline   Reply With Quote
Old 08-18-2016, 05:52 PM   #5
X2
Trevor43 is offline   Reply With Quote
Old 08-18-2016, 06:03 PM   #6
Wobbles's Avatar
I wonder if what you are describing is the motion when the unit goes forward or backward. The jacks prevent the unit from going down on the front or rear, depending which end you walk towards.
The tires are resting but with a person walking to the other end you can get some movement.
I have a double axle TT so my solution was to buy a set of x-chocks to put between the tires. The wheels cannot roll, so no more front to back movement.
https://www.amazon.com/X-Chock-Wheel.../dp/B002XLHUQG
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is online now   Reply With Quote
Old 08-18-2016, 06:14 PM   #7
grhodes50's Avatar
You have to remember these trailers are mounted on leaf springs and tires which are made to help cushion the ride while in transit. So naturally you are going to feel that motion when walking around inside while set up for camping, even when using stabilizer jacks.. That's why some people add (not move the rear stabilizers) jacks near the axle(s).
You can also try a number of products, X-Chocks, etc... to try and help reduce the movement, but you will probably never get rid of it entirely.
Gary & Trish
2017 Nights Camped - 4
Old 08-18-2016, 06:19 PM   #8
Wobbles's Avatar
Talking
X2
Suspension is a contributor. Having said that, If you are getting movement out of the leaf springs, It is a dance party.
Bob & Michelle
Old 08-18-2016, 06:24 PM   #9
TsnTexas's Avatar
X2 on the X Chocks
2016 Rockwood 2504s
2016 Chevy 2500HD
TsnTexas is offline   Reply With Quote
Old 08-18-2016, 06:26 PM   #10
grhodes50's Avatar
Originally Posted by Wobbles View Post
X2
Gary & Trish
jacks
