05-13-2015, 04:25 PM
Stopping fresh water loss when traveling
Filled the FW tank for my first boondocking trip and when I got there it was down to 1/3 full. I figured out it must of came out the relief/overfill valve due to the driving because I couldn't find any leaks. What's the best way to stop this?
TT- '21 Spirit XTR 2146BHX
TV- '19 Nissan Titan XD Cummins Diesel 5.0
05-13-2015, 04:31 PM
Duct tape over it or if it doesn't have a screen over it, a plug of some kind.
05-13-2015, 04:46 PM
we added a shutoff valve to ours, just gotta remember to open it when filling
05-14-2015, 08:59 AM
Boss Ox & Drovergirl
It's not really an overflow but a vent that's routed in the wrong direction and causes water to siphon out. Our RK has this and you can simply rout the end of the tube upward, higher than the top of the tank and it won't do that anymore.
Or as jawga suggests, a shut off valve works but you have to remember to turn it on and off.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
05-14-2015, 12:25 PM
I had the same problem a couple of times in my 2011 Georgetown 327. My solution was to not quite fill the water tank.
The overflow for my fresh water tank rises at least 1" above the tank before heading out the bottom of the compartment. For this siphon effect to work, the overflow pipe probably extends down into the tank, a design feature I don't understand.
Phil
05-14-2015, 01:01 PM
Same problem with my '05 Georgetown.
Put a valve on the end of the vent pipe and it worked great until DW flushed the toilet with the valve closed. Collapsed the tank. Expensive repair. Now we have a sticky note on the pump switch.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
05-14-2015, 01:14 PM
Bill
Funny how atmospheric pressure works. Have you ever seen the video of a railroad tank car collapsing when a valve was not opened to the atmosphere. Many a semi tank truck has had that happen also. I would be careful to avoid putting a valve on the vent. Stuff happens when you forget.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
05-14-2015, 02:33 PM
Fresh water tank
Are you sure it was full. Some tanks or fill lines get a air lock and will burp out the fill point when its not full. Filling slowly will normally overcome this problem. My 5r has the vent routed to the fill point so I don't have the problem but my son in law does and the slow fill works.
05-14-2015, 03:38 PM
Had the same experience with my 2005 Cedar Creek. The dummies at Forest River shoved the overflow line into the tank too far and when the RV was in motion it started a siphon effect which almost drained my tank (on numerous occasions).
The solution was to drop the tank, relocate the overflow tube to the proper height and re-install the tank with overflow tube attached to the vent nest to the fill tube. When FR initially installed the tube they just let in hang down which really made the siphoning easy to start.
I just wonder if manufacturers realize how PO)'d customers can get and how much repeat business they loose..........?
05-14-2015, 08:44 PM
I would be careful as to plugging or closing as pressure will build up. I had to relocate mine higher up on the tank as FW installed about 2/3 the way up. My previous units had a vent at the fill tube.
2013 Salem 30KQBSS TT
Equalizer 4pt Hitch system-12K
2016 Ram 1500 Crew Cab Sport 5.7 Hemi w/8 Speed
05-14-2015, 09:51 PM
I have the 195bh and the FW tank is inside under the bottom bunk bed. The overfill hose is at the top of the tank and just hangs straight down through the floor to the outside. In the photo it's the bottom one that goes straight into the pile of spray foam.
I can't see a simple solution other then putting a shut off valve on the end of hose, but I'm pretty forgetful so it sounds like that may be a bad idea?
05-16-2015, 10:26 AM
Team Bleu
Having same issue with my Georgetown 34. Leaving for a dog show water ran out as I was going down my driveway, never happened before, drove back up, crabs the duck tape and clamp and fixed it. Just saw your reply, what type of valve did you get? Thanks
12-16-2015, 10:18 PM
I never got around to putting a valve on it because all my sites have had water hookup since. But I need to address this just wanting another option because I know I would forget to open the valve.
12-16-2015, 10:47 PM
Quite possible that this would be a cure:
Seachoice Aluminum Anti-Siphon Valve - Star Marine Depot
Lets air in, blocks liquid out.
12-16-2015, 11:51 PM
Another le fix would be to make the vent line longer and put a couple loops in it. Factories use to do this for gas tanks before they were sealed systems. Guys with old cars would know this.
12-17-2015, 04:44 AM
Originally Posted by Bluepill
This valve would cause some Members Big problems as the Vent Hose MUST allow Air In and Out but also Check Water from going Out! Vent/Overflow tube Must be Open to prevent (2) conditions of the F/W Tank, (Imploding and Exploding)! Youroo!!
12-18-2015, 04:18 PM
Been there partially collapsed mine and broke the water hose. I used a simple plastic valve from Lowes but forgot to open at a rest area when DW flushed
Not a cheap fix. Bill
12-21-2015, 09:44 PM
So here's a photo of the inside of the gravity fill going to FW tank. It looks like there is a small place to the right for a tube hookup and there is a screen on the outside the factory covered with silicone. Could I just reroute the vent tube to this connection and remove that silicone?
12-21-2015, 11:21 PM
That looks like mine except you don't have a hose attached. You can attach the vent there and that should cure your problem. With that hooked up, when you fill the tank, that is were the overflow will come out.
12-21-2015, 11:29 PM
Why would they not set it up that way? Scroll up and see my vent line just goes straight down through the floor.
