Old 04-01-2016, 07:29 AM   #1
Suburban Thermostat
Hey everyone.
I have a 2011 Salem Hemisphere 312QBUD trailer I keep down at the lake (200 miles from home). Last fall I was having trouble with my water heater not heating the water on electric. I've replaced the anode rod already (didn't fix), but didn't check the thermostat to see if it has melted like other post on here mention.
I've done some research and think I need to order a Suburban 232317 thermostat switch. Does anyone know if there standard thermostat for Suburban DSI water heaters?
buckeyefan is offline   Reply With Quote
Old 04-01-2016, 07:42 AM   #2
Mr. Dan's Avatar
You probably learned that an anode rod has nothing to do with heating water. Before I would order and spend money on another part, I would jumper across the thermostat with a few inches of insulated wire. If that doesn't make the WH work, a new thermostat will not fix the problem. I'm sorry I can't answer your specific part number question. It was more than 8 years ago that I had WH problems.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 04-01-2016, 08:09 AM   #3
Flybob's Avatar
On the bottom left ( outside) just above the power switch, there are two round black rubber covered circles. They are over temp snap disc switches. Push each one. If one of them snaps, it had tripped and is now reset. Then try again. If they are OK, You may have burned up the heating element, by applying power when the WH tank was empty. Easy to do if WH is left on after a trip and you plug RV in to clean at home.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-01-2016, 08:10 AM   #4
Pickin' & Campin'
Have you checked the element?
As mentioned the anode rod has nothing to do with heating the water.
Maybe you mistook the anode rod for the element?
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 04-01-2016, 08:13 AM   #5
Head Rambler
I'd bet that the element is burned out before I'd suspect the T-Stat. Have you checked the element?
Gotta go campin!
Old 04-01-2016, 08:21 AM   #6
bubbles's Avatar
Not trying to be ugly but RV water heaters does not appear to fall within your realm of expertise and perhaps assistance from someone local to visually assist you with this issue is waranted. Just a friendly suggestion.
suburban, thermostat
