Old 08-29-2019, 03:15 PM   #1
chuck9997's Avatar
Television Channel Scan, etc.
TV question.. I bought a 2017 Salem Hemisphere 23rbhl... there is a television in the camper. I set the channel function to air (not cable), raised the antenna and did a channel scan. It says it picked up a bunch of stations.. but, after the scan is finished I'm getting a message that says RUN CHANNEL SCAN. And im getting no TV stations to view.
Also.. is there a tv signal booster in this camper? If so.. I can't find it. Lol.
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 08-29-2019, 03:25 PM   #2
Flybob's Avatar
Look for the wall plate where the ant cable to the tv connects. There should be a small button that when pushed turns on a red or green led. The amp is in the antenna that is the power source.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-29-2019, 05:01 PM   #3
chuck9997's Avatar
Yep... that's where it has been on every camper I have owned.. but not on this one.
Old 08-29-2019, 05:07 PM   #4
Mr. Dan's Avatar
My wall plate that Flybob mentioned is at the TV mount in our bedroom, not behind the main TV. I helped a guy in a camp once and found his behind a cabinet door in his entertainment center.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 09-06-2019, 10:35 AM   #5
Mine is located at the tv in the bedroom. Forest River Salem 27REI
parrott is offline   Reply With Quote
Old 09-06-2019, 11:43 AM   #6
chuck9997's Avatar
Thanks for responses.. I actually found the power booster button. It is on the "cable/antenna" plate behind the TV. Very small.
Also solved the channel scan issue. Discovered the booster button was broken.. would not stay engaged. Ince replaced.. the reception is fine.
television
