Old 08-03-2015, 08:47 AM   #1
tire repair
I need to have my back left tire repaired that has a screw between the treads. I does not seem to be leaking pressure, but don't want to get stranded or have any hassels on the road. What is the best way to remove the tire and take it to be repaired my self before any more trips.
Eddy G is offline   Reply With Quote
Old 08-03-2015, 08:52 AM   #2
mud yapster's Avatar
discount tire will repair it for free
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-03-2015, 08:55 AM   #3
dbarr's Avatar
Take it to a tire shop and have them dismount it and repaired with a patch inside. Plugs don't work on trailer tires I have found. The back and forth movement and sharp turns pull the plugs out and soon you will be blaming some poor chinaman for your poor quality tire.
'15 F150 Ecoboost Maxtow Scab '13 Freedom Exp. 233RBS
Days camped 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....52
dbarr is offline   Reply With Quote
Old 08-03-2015, 08:55 AM   #4
thanks
Old 08-03-2015, 08:56 AM   #5
After (Back Tracking) looks like you have a (Hemi 2Axle Unit)! Pull (1) tire up on a (Homemade Ramp) after you loosen the Lug nuts on the (Nail Tire)! Take to tire shop! Youroo!!
Old 08-03-2015, 09:01 AM   #6
Discount tire will remove the tire and patch it properly they don't use plugs. Plugs are an emergency use only so you can get where you are going to have it patched.
They will remove it and patch it for free.
Old 08-03-2015, 01:11 PM   #7
Thanks so much, I knew about how patches are better than plugs, but I meant that how could I take it off my self and take it to a tire shop with not the hassell of trying to park it at a limited parking area that most tire shops have.
Old 08-03-2015, 03:42 PM   #8
dbarr's Avatar
Youroo's way will work just fine.
2014-47,
Years camping....52
repair, tire
