Old 09-15-2018, 07:51 AM   #1
Tire Size
Can anyone tell me the tire size that FR puts on the Salem Hemisphere 5th wheel campers? Mine is in the shop for warranty repairs so I don't have access to it to look. I know it has the Castle Rock china bombs. I'm shopping online prices for new tires and want to be able to put in the right size. Thanks in advance.
RobH063 is offline   Reply With Quote
Old 09-15-2018, 08:06 AM   #2
Mr. Dan's Avatar
Isn’t the tire size listed in any of your paperwork from the sale?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 09-15-2018, 08:22 AM   #3
Originally Posted by Mr. Dan View Post
Isnít the tire size listed in any of your paperwork from the sale?
Wow. Do you feel better for scolding me? You don't think I've searched online before I made a post? You shouldn't make assumptions and then tell me Search is my friend. Get over yourself. There's nothing in my paperwork about tire size and I've found no listings online either. I posted what I knew. I thought this was a helpful forum. I must have been mistaken.
Old 09-15-2018, 08:35 AM   #4
Wow, looks to me like he was just asking a legimate question to try and give you some options you might not have thought of.
Having a bad day?
Old 09-15-2018, 08:39 AM   #5
wmtire's Avatar
Moderator hat on:
Rob, not sure why you are getting all bent. Dan was just trying to offer alternatives to you, that you may or may not have thought of.
Now for the "search is my friend" part, that is in Dan's sigline and shows on all posts. You may not have noticed it is under the black line which makes it part of the sig line (just like your "retired deputy sheriff" in your sigline). It was not aimed directly at you or your question, and was not part of his reply to you.
This is a friendly forum, and you will need to keep it as such.
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 09-15-2018, 09:18 AM   #6
Homebrew's Avatar
Be careful reading on line and the sticker on the trailer.
My last two trailers tires did not match the sticker on the trailer. My new trailer sticker shows tire PSI at 90 , the tire shows max PSI at 80.
Get tire info from tire or dealership.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 09-15-2018, 09:22 AM   #7
I would simply CALL the shop where your warranty work is being done and have them read it right off the tire to you!
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 09-15-2018, 09:23 AM   #8
Denver To Yuma In 90 Days
Why not call the shop where the 5'ver is and ask them to look at the tires and tell you what the size is?
Sounds to me like the easiest...and best option!
However, if they are Castle Rock china bombs...they are most likely 225/75/15's!
I put 'E' range Hercules SP2's in that same size on my 5'ver...love them so far!
It had 'D' range tires on it before but wanted the higher PSI of the 'E' tires!
And they were only $1.00 more each than the same tire in 'D' range.
ID:	186500   Click image for larger version
JohnD10 is offline   Reply With Quote
tire
