Is this normal wear for travel trailer tires? We have had our camper for 4 years but have put less than 1000 Miles on it (we use it often just don’t take it far). We noticed this on the tires over a year ago.
It just seems like odd wear to me. It’s on the passenger side and this wear is on the outside.
Not very much Info so this is just a WAG,Salem unit = leaf springs = straight axle=Bent Spindle! Could be from Jacking up under axe tube favoring the Worn side! Youroo!!
Either underinflated or there is some kind of alignment problem.
Not really sure about that. They were worn on outside a lot. Inside a little, and had weird wear patterns as if they were square.
Anyway, changed them to Carlisle HD Trail radial. Could not be more happier.
You don't say which RV you have other than the brand. It might help to know, but at any rate, those axles and spring hardware need to be checked for alignment, wear, and straightness.
There's something out of alignment there.
Gotta go campin!
