Old 07-03-2018, 08:06 AM   #1
Tire Wear
Is this normal wear for travel trailer tires? We have had our camper for 4 years but have put less than 1000 Miles on it (we use it often just don’t take it far). We noticed this on the tires over a year ago.
It just seems like odd wear to me. It’s on the passenger side and this wear is on the outside.
jenstinson is offline   Reply With Quote
Old 07-03-2018, 08:09 AM   #2
"On the road again"
rjshiflet's Avatar
I sure wouldn’t think there is anything normal about this. I’d get a professional opinion from a qualified tire shop though.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
rjshiflet is offline   Reply With Quote
Old 07-03-2018, 08:12 AM   #3
jd50i's Avatar
Definitely not normal, I have 2000 miles on my tires with no odd wear showing.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 07-03-2018, 08:19 AM   #4
Coach
4 years and 1000 miles, there is something really wrong there. Is that the only one worn in that fashion?
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 07-03-2018, 08:21 AM   #5
Not very much Info so this is just a WAG,Salem unit = leaf springs = straight axle=Bent Spindle! Could be from Jacking up under axe tube favoring the Worn side! Youroo!!
Old 07-03-2018, 08:34 AM   #6
Both tires on that side show the same wear.
Old 07-30-2018, 09:46 PM   #7
My tires (China bombs) showed exactly same wear after similar mileage.
Kuba is offline   Reply With Quote
Old 07-31-2018, 12:20 PM   #8
Happy Camper
Tonylmiller's Avatar
Either underinflated or there is some kind of alignment problem.
2021 Forest River Sabre 37FLL
Towed with 2019 Silverado 2500 HD
B&W Turnover Ball Gooseneck hitch
Anderson Ultimate Connection 5th wheel hitch
Tonylmiller is offline   Reply With Quote
Old 07-31-2018, 06:07 PM   #9
Not really sure about that. They were worn on outside a lot. Inside a little, and had weird wear patterns as if they were square.
Anyway, changed them to Carlisle HD Trail radial. Could not be more happier.
Old 10-16-2018, 09:27 PM   #10
Update, did about 3000 miles during the summer on my new Carlisle tires, checked them with a tire gauge and they are all the same
Old 10-17-2018, 10:38 AM   #11
You don't say which RV you have other than the brand. It might help to know, but at any rate, those axles and spring hardware need to be checked for alignment, wear, and straightness.
There's something out of alignment there.
Gotta go campin!
tire
