Old 02-10-2015, 12:35 PM   #1
TN_Cruise_Lite's Avatar
Cool Tires are not rated enough...really?
Looking at the specs for my 195bh it is supposed to weigh 3003 lbs with a load carrying capacity of 881 lbs for a possible total of 3884 lbs. Looking at 205/75-14 Goodyear Marathons, they are rated at 1760 lbs per tire or 3520 lbs total weight carrying capacity. That's 364 lbs overloaded on the tires if fully loaded. How can they sell a vehicle with the specs overrated like that or am I looking at this wrong?
2018 Coleman Light 1805RB
2010 Chevy Silverado 4x4
2013 Salem Cruise Lite 195BH (traded)
TN_Cruise_Lite is offline   Reply With Quote
Old 02-10-2015, 12:42 PM   #2
TURBS's Avatar
Looks fine to me.
Remember your truck carries part of the load via your hitch.
Look at your tongue weight spec you'll then find the weight your missing.
I believe your hitch weight is around 403 lbs.
Old 02-10-2015, 01:15 PM   #3
Flybob's Avatar
As TURBS said, you need to take into account the tongue weight. The specs are set up to make the unit legal, however you will find they build in virtually no margin of safety. That would cost more.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-10-2015, 01:15 PM   #4
jlbreaux's Avatar
No worries, your tongue weight is 400lbs.
http://www.forestriverinc.com/produc...delID=730#Main
2011 Puma Unleashed 365 QLB
2006 GMC HD Sierra SLT quad cab 4x4 6.6L LBZ Allison tranny
2008 Arctic Cat Prowler 650 H1
2006 Polaris H.O. 500EFI Sportsman
1996 Harley Davidson Heritage Softail
jlbreaux is offline   Reply With Quote
Old 02-10-2015, 08:21 PM   #5
Thanks guys for clarifying but as Flybob said, virtually no room for error. Guess I'll be hitting the truck scale at the local Pilot.
Old 02-10-2015, 08:22 PM   #6
TURBS's Avatar
Good idea!
Old 02-11-2015, 01:12 PM   #7
sfsgm's Avatar
I agree with Turbs.
sfsgm is offline   Reply With Quote
Old 02-11-2015, 01:19 PM   #8
vinmaker's Avatar
Right. The TV tongue takes some weight also.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 02-11-2015, 06:51 PM   #9
If you don't replace them all with a heaver duty tire you should at least get "tire minders" for them. With our brand new 5th wheel the tires were very close to the limit and within 3000 miles we had 2 flats. We ended up buying 5 new heaver tires 600 miles from home to continue the trip. Because we had the tire minders we knew as soon as they blew (one was at 60 mph) and we were able to stop before we did any damage to the rim or the trailer. I wish I had put the heaver duty tires on at the start when it was convenient close to home rather then have to try to find a place 600 miles from home that would do the trailer tires the next day.
bplantcjf is offline   Reply With Quote
Old 02-11-2015, 11:14 PM   #10
retiredguy's Avatar
I 100 percent agree with this post. A tire minder saved me a major problem. It let me know I was having a flat, and by the time I got stopped the tire ahead of it was also separating. I went from "C" rated to "D" when replacing the factory installed tires.
2013 Windjammer 3025
2018 Heartland trail Runner sle 265
2012 GMC 3500 6.6
2011 Razor 800
http://dougbevswanderings.blogspot.ca/
retiredguy is offline   Reply With Quote
tire, tires
