Old 05-07-2019, 11:39 AM   #21
Denver To Yuma In 90 Days
Originally Posted by Mountndream View Post
one other thing.. if your stairs fold under the door and you experience a lot of bouncing entering and leaving the trailer. The MorRYDE stepAbove elimanate this. Some people don't like them, but they can't argue the physics involved
The Torklift GlowSteps are another lightweight option...
I have them and love them!
JohnD10 is offline   Reply With Quote
Old 05-07-2019, 12:50 PM   #22
On my 38ft 5th wheel, the JTStrong Arms did the most to stop the bouncing. I had tried the 5th wheel nose stands, and support jack stands along the frame as well, but the JT Strong Arms worked best by far. The other thing I did was to add 2 of the standard stabilizing jacks on the frame, in the middle of the trailer, which happens to be next to the door and at the front of the slides. This also helped with movement when entering and exiting since those stabilizers were right next to the door.
JMTrice is offline   Reply With Quote
Old 05-07-2019, 12:53 PM   #23
I have the same issue in my Roo. This year I'm trying step stabilizers and additional jack stands on the frame.
RooMan183 is offline   Reply With Quote
Old 05-07-2019, 12:53 PM   #24
The Steadyfast system gets my vote to remedy your movement concerns.
I use the X-chocks which eliminates a lot of the trailer movement combined with the Steadyfast system all is good.
2018 Flagstaff 26RBWS
Equalizer 1,200/12K WDH
2018 GMC 2500HD Crew cab 6.0L
deereman1026 is offline   Reply With Quote
Old 05-07-2019, 01:40 PM   #25
Stability
I started w/ slide-out stabilizers. Switched to X-chocks, which I feel do a better job. But, I have also learned to level the slide side high when I level the trailer. This is on a V front w/ two slides on the same side. I also now carry more blocks, so I do not extend the stabilizers as far. Made the trailer much more stable.
Tundra 2014 is offline   Reply With Quote
Old 05-07-2019, 01:51 PM   #26
Trailer Park Supervisor
NJKris's Avatar
I think this is the key. I was told by the dealer that the stabilizers work best when they are not extended way out. At home on my driveway (and it is not steeply sloped)I have a cinder block and three one inch thick boards, maybe thicker, beneath the 2 rear stabilizers AND had to crank stabilizers down a good 5 inches to reach the cinder block/board combo.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 05-07-2019, 02:16 PM   #27
I've always managed to get by with 4 chocks. In front of front tires and rear of rear tires. I block up my stabs so they extend about 1/2 or little over 1/2 way when the hit the blocks. I use rubber mallet to pound chocks in and it's served me well for 35 years. Popups and TT's.
TheWolfPaq82 is offline   Reply With Quote
Old 05-07-2019, 03:33 PM   #28
Telstar's Avatar
JD Stabilizers on front and rear will definitely help.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 05-07-2019, 04:02 PM   #29
The best think I did was wait until Camping World had their yellow 10 piece leveling blocks on sale, I bought 4 of them, put one set under each stabilizer and that eliminated probably 75 percent of the movement!
I tried the X blocks, I didn't think they worked well, I suspect that with torsion bar suspension, it just didn't work well!
2018 Flagstaff 832IKBS Travel Trailer.
2015 Silverado High Country.
jackhartjr is offline   Reply With Quote
Old 05-07-2019, 07:27 PM   #30
Our 8529IKBS has torsion suspension and the X-Chocks work great. Put them in and make them tight and they will not allow the tires to rotate.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 05-07-2019, 07:47 PM   #31
Iwannacamp's Avatar
Trailer bounces with any movement!
Another thing. Some people add a set of stabilizers in front(or back) of the axles. This is is supposed to help.
We have a 5er(front legs of course), scotches, x-chocks(DW says they help), JT strong arms and it still moves. I guess it’s just a trailer.
I forgot step supports...only helps going in and out.
2017 Puma 297RLSS
Old 05-07-2019, 08:25 PM   #32
Brother Les's Avatar
'Stabilizers' stabilize.... they do not stop movement. I have a set of 'stabilizers', front and back that came with the unit.... good for nothing junk to keep unit from 'moving'... solution... install scissor jacks at the corners and slightly lift the unit. one x-chock and 4 scissors jacks, problem solved.
Brother Les
Old 05-07-2019, 08:33 PM   #33
Jayhawker
Jayhawker's Avatar
Try these JT Strong Arm stabilizers
2018 Surveyor 243RBS
Jayhawker is offline   Reply With Quote
Old 05-07-2019, 09:25 PM   #34
NorSnrub's Avatar
Everything helps but no complete cure.
NorSnrub is offline   Reply With Quote
Old 05-07-2019, 09:46 PM   #35
BigHomey's Avatar
When we had a TT, we used a set like this if we going to be set up for more than a night:
https://smile.amazon.com/Cynder-0204...gateway&sr=8-9
One either side half way between the wheels and front and same in the rear. We set them each on a 2x12 12" long directly under the frame. If you get any movement then, your frame is flexing. They are available in different height ranges.
AL
2016 Coachmen Mirada 35KB
2016 Jeep Cherokee 75th Ann. Ed.
2007 Corvette Convertible
1997 F-350 CC PSD
BigHomey is offline   Reply With Quote
Old 05-07-2019, 11:25 PM   #36
I used the SteadyFast stabilizers on my fiver. They took about 90% of the movement out.
free83118 is offline   Reply With Quote
Old 05-08-2019, 08:46 AM   #37
NJKris's Avatar
Holy smokes, what do you do in that trailer, have barn dances? lol.
Old 05-08-2019, 09:05 AM   #38
Kris, they really do make a difference...
Name:	jts front.jpg
Old 05-08-2019, 09:07 AM   #39
NJKris's Avatar
No doubt! Don't think I'll ever need that much stabilization though.
Old 05-08-2019, 09:12 AM   #40
You won't but the DW will!
trailer
