Old 05-27-2014, 09:56 AM   #1
TV mount in bedroom
I have a tv mount I want to add to the bedroom of my 282rk hemi, what is the best type of screws / wall braces to use to secure it. The walls seem so thin and I don't want to have the tv tear the wall apart....or put a screw in and have it come out the other side.
Mike
Sent from my SM-N900V using Forest River Forums mobile app
mbaker5408 is offline   Reply With Quote
Old 05-27-2014, 10:06 AM   #2
AquaMan's Avatar
You will have to mount it to a either a wall backup plate(factory installed) or you may be able to go directly into a wall stud using the correct anchors.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 05-27-2014, 10:33 AM   #3
So best to talk to my dealer or fish a plate in through the cable wire hole.
Or see if there is a stud near by.
Mike
Old 05-27-2014, 11:18 AM   #4
AquaMan's Avatar
Mike
If the plate isn't factory installed, there isn't a way to get one in there and secured, as the walls are foam filled. Mounting to a stud or across 2 studs is about your only alternative, and even that will only accept a TV up to a certain weight. I wouldn't hang 50" on an RV stud.
Old 05-27-2014, 11:22 AM   #5
It is just a 29" samsung nothing major after all I just plan on watching news and what not before going to sleep.
Old 06-30-2014, 10:11 PM   #6
Just a fyi. I took the mount to the dealer and they were able to mount it to the right of the power outlet. No problems at all......thanks for the advise. (Oh and he didn't charge me....even better)
Old 07-03-2014, 11:07 PM   #7
tlambert's Avatar
Could you post some measurements and pictures of it installed. Also what type of mount you used and where you bought it.
I have the same TT and would like to do the same thing.
Thanks Tim.
Tim
tlambert is offline   Reply With Quote
Old 07-03-2014, 11:45 PM   #8
I am out this weekend, I will see what I can get for you...
Old 07-04-2014, 07:47 AM   #9
tlambert's Avatar
That would be great. Thanks.
Tim
Old 07-10-2014, 11:04 AM   #10
Sorry I didn't get photos or anything on or last trip out. I ended up having a small stroke on the first day. I will get those to you next week if that's ok.....
bed, mount, roo, tv mount
