Old 08-29-2019, 09:16 AM   #1
TV Mounting
Hi guys! Weekend camping trip cancelled due to the potential hurricane here in Florida so I figured I would use the spare time to mount a TV in the TT. I have a 2019 Salem FSX 179DBK and would like to mount a TV. I have a sticker that is noted "TV Backer". My question is what is behind that wall? How far out beyond the sticker is safe to mount a TV Mount? Anyone mounted a TV in this particular model? Thanks in advance!
Modrodr is offline   Reply With Quote
Old 08-29-2019, 09:43 AM   #2
Not your model, but the backer in my Cherokee, 2018 was larger than I figured it would be. Just sounding it by knocking on it, I estimated my to be around 18-20" x 18-20". I hung a 40" on the wall and used Lag bolts about 1/4" shorter than the thickness of the wall.
TheWolfPaq82 is offline   Reply With Quote
Old 08-31-2019, 12:09 PM   #3
Thanks for the help. Knocked around and found where it seemed the most solid. All went well
ID:	213887   Click image for larger version
ID:	213888   Click image for larger version
Old 09-05-2019, 06:35 PM   #4
We are looking at this model TT. What size television did you go with?
VOLguy is offline   Reply With Quote
Old 09-06-2019, 07:49 AM   #5
Went with a 24" on an articulating arm. Honestly I probably wouldn't go bigger in this trailer. The trailer as a whole works well for our family. Easy to pull, fits in most campsites and the outdoor fridge is something I will make sure every TT I buy has. Great for 2-3 night trips. LMK if you have any other questions etc.
Old 09-06-2019, 07:20 PM   #6
Thanks! That's about the size I thought would work. Good to know it's working well for you.
Old Yesterday, 04:38 PM   #7
I mounted a 32” similar to the other pictures on a rotating mount. Works well. Wouldn’t go larger than a 32”. The mount I got off amazon locks so it doesn’t swing when moving.
Jchbdawgs is offline   Reply With Quote
mount, tv mount
