Old 08-21-2015, 07:31 AM   #1
TV Mounting
Has anyone ever mounted a TV on the Interior of one of these Salem TTs? I'm a first time RV'er so I don't know what I don't know.
Are there studs in the exterior walls like normal house construction? If so, how thick are the exterior walls?
I'm looking to mount a small 20" or smaller TV on the opposite wall from the door above the window.
Any thoughts?
2014 Ram 1500 Crew Cab 3.6L V6
2014 Forest River Salem Cruise Lite 184BH
signalwarrant is offline   Reply With Quote
Old 08-23-2015, 07:02 PM   #2
I guess this is a dumb question.
Old 08-23-2015, 08:32 PM   #3
2013leprechaun319dsf's Avatar
Buy an electronic stud finder at Lowes (around $15-$20).
See if you can find studs, that should answer your question.
2013leprechaun319dsf is offline   Reply With Quote
Old 09-06-2015, 02:14 PM   #4
TV install
I have a new Salem Cruise Lite slightly larger model 262bhxl. This is actually set up for TV with CD/DVD player. The wall between the living area and front queen actually swivels to watch from either side. Anyway, put a wall bracket in and installed 32 inch flatscreen for those evenings and rainy days. I don't leave it handing when travelling though.
On any install not set up for a tv you will need to chase down wiring so it could be a bit of hassle. probably could get a schematic from the manufacturing to show where wiring currently is located. good luck.
tuckr2 is offline   Reply With Quote
Old 10-24-2015, 09:52 AM   #5
I have a 2016 21RBS. The sales guy told me that there is plywood behind the wall material. There is a space of about 1 1/2 inches between the wall space where the TV is set up to go, and the bathroom wall. I bought a TV wall mount (light weight for RV use) and used several 3/4 wood screws. I just watched from the backside (bathroom) to make sure nothing was coming through. I hung a 32" Vizio LED HDTV and I also put up an earthquake type strap that I secure the TV against the wall while traveling. So far, no problems.
mike4339 is offline   Reply With Quote
mount, tv mount
