12-13-2015, 06:39 PM
TV sound does not feed through ceiling speakers
I have my wall-mounted TV working now (after getting the wall bracket mounted and the TV on it) but the sound does not come through the coach's ceiling speakers.
I have not tried playing a DVD through the DVD player to see if that works yet. I have tried using the remote to the DVD player to find the set up menu (which I think is necessary to program the TV installation) and can't get the set up menu on the DVD player to appear in order to do this.
I'm taking the trailer in for a couple of minor things and will ask about this, but thought I'd try getting the TV to work my self. The AM/FM radio works through the ceiling speakers but the TV does not. I have double checked the audio and video cables from the TV to the wall jacks. Maybe this is my problem.
Any suggestions would be appreciated.
"It is what it is!
2016 Salem Cruise Lite 261BHXL
12-13-2015, 08:40 PM
I go RV'ing not Camping
you would need to put the red/white cable into the Tv Audio out. Then the reverse into the trailer stereo, Red/white into the Aux in and it should work.
My trailer only worked in the ceiling speakers when playing a dvd, which is how it was wired from the factory.
Unfortunately you can't have it both ways without re-wiring
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
12-14-2015, 09:04 PM
you could do it if your tv has a dedicated headphone jack. route it into your aux on the trailer stereo, and route all of your gaming systems and DVD players directly into the tv. tv will take care of the rest.
01-28-2016, 09:52 PM
The sound plays through the speakers while watching a DVD that's played on the built in unit. If you want it to play through the speakers while watching regular tv you have to use the headphone jack on the radio and the audio out on your tv.
Kelly and Stephen with Daisy, Lily, and Roxy!
Run Free Sweet Riley 2009-2015
Visit our blog for more information and details!
www.kels4g.com
01-28-2016, 10:33 PM
Headphone jack on tv to aux input on radio/DVD player. Works great for me!
02-02-2016, 02:44 PM
You might go and check your set-up menu on your tv. Our Hemisphere is covered for winter now, but I believe to get the sound to come through the ceiling or outside speakers' I had to turn the tv speaker to "off" so that the sound is routed through the receiver......I have to go through it all and re-fresh my memory every season. :0/
Salem Lite Hemisphere 232IS
Ford F-250 Super Duty Lariat Crew Cab v-10
02-09-2016, 12:23 PM
Our speakers only work with the DVD player, we could never get regular tv to stream through the surround sound
02-09-2016, 12:41 PM
Surround sound on tv?
I ran a connection out from the tv headphone to the DVD AUX input slot. Switch the radio/DVD function to AUX. You will have surround sound!
02-09-2016, 12:42 PM
This was also true with our Sierra. The TV had line out jacks with wires connected to them and the stereo, but to get sound out of the jacks, the internal speakers had to be turned off. This was done in the TV menu under audio.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
02-15-2016, 08:32 PM
Our setup requires the TV audio out (red & white cables) to be routed to the audio or Aux in jacks in the stereo. Then to listen thru your ceiling speakers you have to change the stereo to Aux input. Turning down the TV volume might be desired also.
Hope this helps.
2015 FR Salem 286RLT Hemisphere 5th wheel
F250 Diesel Laredo Crew Cab
Traveling the highways & bi-ways . . .
with our girls, the maltese pups . Happy Trails
02-20-2016, 11:15 PM
Ours is in getting warranty work done. One of the items on the list was no sound from outside speakers. The dealer called with an update. They had to replace the entire stereo system. It wasn't putting output to the c (outside speakers) output.
Charlie & Anita Pepin
Bruiser and Baxter fury kids
2014 Dodge Ram 2500HD with 2016 Salem Hemisphere 272RLIS
02-21-2016, 01:56 AM
All new stereo...can't complain about that!!
03-13-2016, 12:57 PM
What model do you have? My new 2016 356QB just had the outside speakers quit working. They light up, but no sound. I have checked all wires and the appear to be good connections. They don't work with radio or dvd.
03-13-2016, 01:00 PM
I just had my 2016 hemisphere in for warranty work and that was one of the issues. No sound to outdoor speakers. They ended up replacing the entire radio. It had no output to the c channel
04-08-2016, 05:23 PM
I also use a connector from TV headphone jack to aux port on stereo...work fine.
2014 Salem 27RKSS
