Old 07-25-2013, 07:15 AM   #11
Dave_Monica's Avatar
Originally Posted by Jjs2000z View Post
I have the 2014 ak2612 with the outside kitchen. Where does that sink drain to? Can I add additional grey tanks? My unit has 106 fresh tank & extra 60 gal fresh tank
The only way to know for sure is to run water at that sink and see what gray tank it drains out of. What about using a portable tote to handle gray water...much less expensive than adding a permanent tank. You may not have any room for one between the frame rails without other interference.
Dave
Old 07-25-2013, 11:17 AM   #12
Jjs2000z's Avatar
I will give that a try
2014 stealth 2714
Jjs2000z is offline   Reply With Quote
Old 07-25-2013, 11:48 AM   #13
The Salem 27rkss grey water tanks are not connected. Good luck in getting capacity, a friend has had one for 2 years and has been asking the same question. The manufacturer rep did not even know there were 2 tanks. We are going to fill the galley tank and empty into 5 gal buckets to get an estimate when we are together in August. I will post the results if you do not have an answer by then.
The easiest way to add an additional tank is to buy a portable "honey wagon", but you will need a place to dump. I can't imagine trying to retrofit an additional holding tank to a TT.
2014 Flagstaff 27RLWS
2004 Chevy Avalanche 2500
1998 21' Thor (doesn't everyone need 2 TT's?)
eshenderson is offline   Reply With Quote
Old 07-25-2013, 12:16 PM   #14
jevanb's Avatar
when I wanted to know I just ran a hose into the shower,sink,other sink, and kitchen sink and waited to see which light/ control switch it indicated, did it for all the tanks, 2 black, 2 gray
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 07-25-2013, 12:24 PM   #15
Dallas Texas
TexasBBQ's Avatar
When I bought my used 5ver the labels for the two grey tank valves were faded and couldn't be read. So I went to Wally World and got some of those colored pellets that kids put in their bath water to make it a certain color. They have about 5 different colors.
I disolved one in the kitchen sink and another in the bathroom sink. Drained the tanks and that told me which went where and which valve controlled it. I then did another color in the shower and learned it used the same tank as the bathroom sink.
Just an idea...
I gave the rest of the pellets to the grandkids.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 07-25-2013, 12:56 PM   #16
arff2108's Avatar
Thanks but I know which drains where. I am trying to find how big the holding tank is for my Galley(kitchen) on my Salem 27rkss. the galley has its own level light and separate drain on other end of tt from the grey water for bathroom which is 69 gallons as listed in tt info. I cannot find anywhere the capacity of the galley tank though.
Salem 27rkss
2005 Ram 1500
arff2108 is offline   Reply With Quote
Old 07-30-2013, 12:22 PM   #17
Dallas Texas
TexasBBQ's Avatar
Are you able to see your tanks or are they enclosed? I got the manufacturer PN and name off mine and looked them up.
2004 Cardinal 33CKT
