Old 07-23-2012, 10:47 PM   #11
Night Stone's Avatar
I will do that, probably this coming weekend, or when the temperature here lets up. Too darn hot atm, specially inside the trailer
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6)
Days camped in 2015, 0 Days so far (0)
This Space for Rent
Night Stone is offline   Reply With Quote
Old 07-23-2012, 11:18 PM   #12
Taranwanderer's Avatar
Ours has only one small outside-accessed storage compartment, and it projects into the space under our bed. But then the bottom of our bed also lifts up, there are two pneumatic struts that lift-assist the plywood right up. Then there's more area for storage. It was never screwed down or closed like that...
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 07-29-2012, 02:26 PM   #13
ok, got a look inside under the main bed, here are the pictures, and it looks like alot of wasted space just to have the fresh water tank there. Wonders why FR decided to do it this way?
Could they have mounted it differently and still have outside storage?
FRF and FROG member
This Space for Rent
Old 07-29-2012, 03:46 PM   #14
We have a 2013 181bhxl the only outside storage we have is under the bed. Looks very similar to your pictures but the tank is moved over. Ours is different than the floor plan you have just a bit. The storage table next to the couch is on the other side. I wonder if you can have different models within a model?
Jamisonhouse is offline   Reply With Quote
Old 07-29-2012, 04:37 PM   #15
That looks like a big waste of space alright. I would hinge and strut that and use it for storage. Or even easier you could drill a small hole in the wood to use as a finger hole to lift up the wood and just leave the screws out.
One word of caution would be to make sure nothing goes in there that would puncture the water tank or wear a hole in it while going down the road.
Be forewarned that I am not an expert and maybe there is some method to their madness.
Maranatha is offline   Reply With Quote
Old 07-29-2012, 06:09 PM   #16
I have one outside storage door, that is on the driver side, which is basically under the couch. But everything else is according to the floor plan with the exception of no outside storage in rear part of trailer, passenger side.
FRF and FROG member
This Space for Rent
Old 07-29-2012, 10:56 PM   #17
So after looking at your trailer pictures two things first is I dont have a outdoor storage compartment like yours under the couch. Second is where my storage door for the under bed is your awning rackets are sitting in its place. Maybe that's why they didnt include the door.
Old 07-29-2012, 10:59 PM   #18
The side of our trailer
Old 07-29-2012, 11:00 PM   #19
I wonder if one is manufactured in Indiana, the other in California? Or basically NW region has different rules versus, SW region or California?
FRF and FROG member
This Space for Rent
Old 07-29-2012, 11:03 PM   #20
ID:	17271   Click image for larger version
ID:	17272   Click image for larger version
bed
