Old 09-08-2013, 09:43 PM   #1
dlhigdon's Avatar
Upgrades and Modifications
Getting to do a few modifications to my 2013 QBUD346. I just got my LED bulbs to replace the factory bulbs in the camper, LED light strip for under the awning, 2-6 volt batteries, a 2500 watt pure sine wave inverter, automatic transfer switch and marble/glass back splash for the kitchen.
I will be starting%
dlhigdon is offline   Reply With Quote
Old 09-08-2013, 10:23 PM   #2
Denver, CO
garbonz's Avatar
2017 Fuse 23T
Old 09-09-2013, 05:52 AM   #3
dlhigdon's Avatar
Sorry. I'm not sure what happened to the rest of the message. I will be starting with the transfer switch and inverter then to the LED lighting and back splash. I will upload progress pictures as I go along for anyone that is interested.
Old 09-09-2013, 06:26 AM   #4
TURBS's Avatar
We love pictures!
As a matter of fact the saying goes aero nd here "no pics then didn't happen"
Have fun!
Turbs
Old 09-29-2013, 02:50 PM   #5
dlhigdon's Avatar
Here is the LED awning lights we installed. Purchased the waterproof light strip on EBay for $10 delivered. More mod pictures to come.
Old 02-10-2014, 01:52 PM   #6
Hi. Old thread I know.
I just bought a similar trailer and wanted to do the led light strip as well.
I was wondering where you routed the wiring for the 12v and if you tapped into an existing 12v line or just ran a new one.
I really want to do this mod, just want to do the cleanest install possible!
warno is offline   Reply With Quote
Old 02-10-2014, 06:20 PM   #7
dlhigdon's Avatar
Hi Waro,
I used the channel that the powered awning cable runs through down to the hole in the side of the fifth wheel where it ties into the 12 volt bus bar. Then I drilled a hole in the side of the under belly compartment where I installed a switch and tied the 18awg wires from the switch to the bus bar in the battery compartment. Hope this helps and just FYI I purchased the light strip on eBay for a fraction of the cost to buy it locally.
Good luck and let me know if you need any other assistance.
Cheers,
Dave
Old 05-04-2014, 08:38 PM   #8
dlhigdon's Avatar
So I have a few pictures to update everyone on the status of the inverter and auto transfer switch install.
First a picture of some of the equipment and tools I used to complete the install.
Name:	ImageUploadedByForest River Forums1399252461.711478.jpg
Next I had to remove the double light switch for the through storage light and the light by the king pin hitch. This was removed so I could cut the hole to install the inverter.
Name:	ImageUploadedByForest River Forums1399252645.707259.jpg
Once the switch was removed I made a template of the inverter out of cardboard and cut the hole for the inverter in the 3/4" plywood between the through storage and the factory battery storage compartment.
Name:	ImageUploadedByForest River Forums1399252951.689031.jpg
Name:	ImageUploadedByForest River Forums1399252821.617284.jpg
Name:	ImageUploadedByForest River Forums1399252839.665856.jpg
This was the best location I could find for the inverter due to the close proximity to batteries and the 12 VDC terminals for the camper DC power supply. (I removed the original 12V battery when we bought the camper last summer and installed 2 new 6V golf cart batteries in the front storage compartment.)
The Go Power Automatic Transfer switch is installed behind the finished wall in the through storage compartment. (I forgot to get a picture of the transfer switch install location to post. I will do that when I go to the fifth wheel next time.)
I removed the converter/charger from under the main electrical panel and installed it inside the factory battery compartment with the inverter and tied it into the transfer switch as per the schematics supplied with the Go Power Auto Transfer switch.
Name:	ImageUploadedByForest River Forums1399253499.201934.jpg
ID:	51633Click image for larger version
Name:	ImageUploadedByForest River Forums1399253663.771537.jpg
I have a few more things to do in order to put the system in operation. If you are interested I will post more pictures and description of the work I complete as I go. Hope you enjoy the post!
Old 05-04-2014, 08:40 PM   #9
dlhigdon's Avatar
Name:	ImageUploadedByForest River Forums1399253996.309377.jpg
ID:	51635Click image for larger version
Name:	ImageUploadedByForest River Forums1399254009.340981.jpg
These pictures didn't upload properly on the previous post.
Old 05-04-2014, 09:00 PM   #10
So let me get this straight...once you loose "shore power" the inverter kicks in?
Kuba is offline   Reply With Quote
Old 05-05-2014, 07:02 AM   #11
dlhigdon's Avatar
Hi Kuba,
Yes with the automatic transfer switch when shore power is disconnected or not hooked up the inverter. The automatic transfer switch has normally closed, normally open and common contacts. The shore power and the charger are on the Normally Open (NO) contacts and the inverter is on the Normally Closed (NC) contacts and the AC panel is on the common contacts. This means the inverter is always on feeding the AC panel unless the shore power is plugged in. When the shore power (generator, AC power) is plugged in the Automatic Transfer switch changes state and the switch goes from NC state to NO state. When the transfer switch changes to NO the charger will automatically turn on and start charging the batteries.
Old 05-05-2014, 07:29 AM   #12
bubbles's Avatar
Just curious. Understand the contacts but what/how are the contacts switched. Is it an AC/DC coil/solid state/current sensing or what?
Old 05-05-2014, 08:06 AM   #13
Kaadk's Avatar
I like the concept, but I didn't see anywhere on the schematic where you'd put a disconnect. How are you planning to prevent battery rundown while in storage?
Old 05-05-2014, 10:48 PM   #14
dlhigdon's Avatar
There is a relay built into the automatic transfer switch along with a small circuit board. Hope that helps.
Old 05-05-2014, 10:51 PM   #15
dlhigdon's Avatar
I have a 12VDC disconnect which I will install on the positive wire between the inverter and battery terminal along with a fuse and fuse block. I will update the thread with pictures when I complete this step.
Old 05-19-2014, 05:43 PM   #16
dlhigdon's Avatar
More pictures or my upgrades. Click image for larger version
Name:	ImageUploadedByForest River Forums1400539213.625673.jpg
Had to fish wire for the meter control wires for monitoring the battery voltage, amperage and amp hours.
Name:	ImageUploadedByForest River Forums1400539295.220520.jpg
Finish meter installed in wall.
Name:	ImageUploadedByForest River Forums1400539330.813789.jpg
Name:	ImageUploadedByForest River Forums1400539345.550757.jpg
The old battery compartment with the inverter and charger installed.
Name:	ImageUploadedByForest River Forums1400539396.482969.jpg
Inverter with remote installed and operational.
Old 05-19-2014, 08:55 PM   #17
Nice!
Old 05-30-2014, 08:11 AM   #18
noprobrob's Avatar
You have pics of the backsplash complete?
noprobrob is offline   Reply With Quote
