Old 09-25-2015, 10:30 AM   #11
n-e-d's Avatar
Location: Home of the 4 time Super Bowl Champions Patriots and we'll be there again
Flybob's advice "Do not let your excitement cloud your better judgement" should be the number 1 golden rule on any PDI
Mary and Me
2015 2650s
2015 Jeep Cherokee
n-e-d is online now   Reply With Quote
Old 09-27-2015, 04:03 PM   #12
Kbryant099's Avatar
YOU operate everything. Let them show you how but don't let them do it. Doing it is how you'll remember. Also take videos as necessary.
Kbryant099 is offline   Reply With Quote
Old 09-27-2015, 05:39 PM   #13
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
Due to my personal experience in taking delivery of my last TT, take your own tire pressure gauge with you and check each tire AFTER your PDI guide shows you on the list that they had been checked. If you find as I did, that the tires don't have anywhere near the right pressure, it will let the guy know you will be checking everything else and they better be as shown on the list.
The PDI I was presented, said the tires had 65 psi and had just been checked. Like a fool and wanting to get out of the rain, I believed him. Long story short, I drove 250 miles before I finally stopped to check them as it was NOT riding well. If it hadn't been raining to keep them cooled down, I probably would have popped all 4.
Make them show you everything on the list as the devil is in the details. You won't get another first chance.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 09-27-2015, 06:01 PM   #14
asquared's Avatar
Do not hand over the final cash until everything works to your satisfaction. Do not let them tell you to bring it back under warranty. Be prepared to either come back another day or walk away altogether if necessary. As others have said, if it turns on or off, opens or closes you want it demonstrates and you return the demo. Video the whole pdi. Have them show you (not just tell you) how to winterize and dewinterize. Learn where your water heater, water pump, low point drains etc are. Check all caulking, the roof, look for any sign of water intrusion. Look at little things too like screws and nails. We found a overhead cabinet coming apart. Make sure lights, tv's, radio's, etc work. Light the stove and oven. Boil a cup of water in the microwave. Our microwave ran but didn't heat. Check to make sure all doors and slides line up properly and operate properly. There is a pdi list in the forum library you can look at. Also, you have a roundhouse so if you have kids, get a babysitter do they don't distract you. If they must come, set them up with a movie or something while doing your pdi. Look into forest river second year factory warranty (also in forum library) before buying an extended warranty. Finally, don't forget to have fun!
<a href= target=_blank></a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 09-27-2015, 06:17 PM   #15
Many folks like to tape record, video the walk thru so as to remember all the STUFF then tell you.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 09-27-2015, 06:31 PM   #16
The_Rhino's Avatar
I purposefully viewed the actual TT we were buying in HEAVY rains so that I could personally verify there were no leaks. A new one (same model as ours) was leaking badly whereas the used one I eventually bought was bone dry. (Salesperson verified all windows & skylights were shut but a steady stream ran across the dinette floor - probably a bad slide seal...)
I spent about 2 hours checking our TT out BEFORE making an offer. I took a screwdriver & looked behind EVERY access panel with a flashlight for signs of prior leaks, etc. I especially checked the pump & water lines inside for signs of leaks. I made a list of everything I wanted them to address (mostly cosmetic - loose trim or cabinet doors)...
In addition to those repairs, the dealer performed a pressurized leak test & re-caulking while we setup financing. When we arrived for the PDI they were still caulking & adjusting the awning so that it would fully retract. They also adjusted both slides - said the cables were a little slack - good to know because I thought the slides worked fine...
We videotaped the 2.5 hour PDI. They filled all tanks to check for leaks. They ran everything gas, 12V & 110V. They replaced the CO2 detector & filled the propane tanks. They also showed us how to retract the slides using a cordless drill & (provided) adapter. While we were at the PDI another mechanic installed our Equalizer 4 WDH & by the end of the PDI they showed us how to hookup & adjust the WDH (which we never had to do - they got it right).
Two summers later we have not had any serious issues not caused by me. (I bent & replaced a rim... I lost my balance & tore-off a cabinet door... After a few bad connections at State Parks I had to replace the 30A male connector - but everything so far has been easy DIY fixes...)
We paid about the same for our used TT at the dealer as folks were asking on Craigslist, etc. However, the dealer included the pressurized test & re-caulking, slide cable & awning adjustments, 2.5 hour PDI, FREE Equalizer 4 WDH & WDH setup, plus some store credit for supplies - all within our sale price.
2011 RAM 2500 ST Crew Cab 5.7 Hemi
2011 Primetime 3150BHD Touring Edition
Days camped in 2016-36
Days camped in 2015-37; Days camped in 2014-31
The_Rhino is offline   Reply With Quote
Old 09-28-2015, 05:55 AM   #17
Wacipi's Avatar
Make sure your phone is charged well. I close up recorded every instruction and asked questions at the same time. Not all switches are marked well. Ask those questions on video. Photograph up close, hands and equipment. You don't need to get whole people, this is for later reference. I have about 25 short videos from my walk thru. How to operate this and that. Where things are located. The on/off position of switches and what they are for. Everything. Believe me, you will want those videos later. If I put mine all together, they would make a great how to movie. That's what you want. Each video short and sweet and up close with volume up. Ask questions!
2015 Forest River Salem T29FKBS - Super newbie on every level
Wacipi is offline   Reply With Quote
Old 09-28-2015, 10:24 AM   #18
Boss Ox & Drovergirl
oxcamper's Avatar
Don't sign the papers until you have the walk through and get in writing anything that needs adjustment or repair.
We took videos of the water heater by pass procedure and how to manually extend/retract the slide and power jacks and tongue.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 09-29-2015, 03:09 PM   #19
Thank you Everyone for your fabulous tips !!! Hubby and I have printed it all out and are scheduled to do our walk thru Thursday am SO excited.....both phones will be charged and ready !
Thanks again !!!
MrsTish is offline   Reply With Quote
