Old 09-02-2018, 01:34 PM   #1
moshe1436's Avatar
Wall construction question
I want to mount a ladder on the rear cap of my 2014 Salem Cruise-Lite 241QBXL. But I don't know how to find the studs (hopefully they're there!) to attach the screws for the ladder. Can anyone tell me how to find the studs? Thanks!
Mo and Jeanette
2014 Forest River Salem
Cruise-Lite 241 QBXL
moshe1436 is offline   Reply With Quote
Old 09-04-2018, 06:42 AM   #2
SeaDog's Avatar
go to home depot or harbor freight and pick up a stud finder that has the deep scan feature you should be able to find the studs that way
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 09-04-2018, 06:47 AM   #3
moshe1436's Avatar
Wall construction
I have a magnetic stud finder but I donít think itís a deep scan type. I will try mine first and if necessary pick up the deep scan type. Just wasnít sure if any stud finder would work through the aluminum skin.
Thanks for your suggestion.
Old 09-04-2018, 07:12 AM   #4
SeaDog's Avatar
Have you bought about the option of a collapsable ladder? If my rig didn't have a ladder I would go that route. Also if your stud finder doesn't work with the aluminum skin move inside and check for the studs and transfer you measurements outside just a thought.
Retired Navy
Old 09-04-2018, 07:42 AM   #5
cavie's Avatar
Most rigs have an alm frame these days. Mag finder won't work.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 09-04-2018, 01:57 PM   #6
moshe1436's Avatar
Thanks for a couple of good ideas. Checking inside should detect the studs. I'll give that a try.
Mo and Jeanette
Old 09-04-2018, 02:11 PM   #7
onetonford's Avatar
I think that most RV's with aluminum framed sides but the end walls are wood studded I know my 2011 Wildcat has wood studs on the back wall When I redid the Tail lights I found it had a wood frame in the back wall.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 09-04-2018, 02:12 PM   #8
bikendan's Avatar
The OP has a stick and tin trailer, so it has wood frame construction.
Equalizer WDH
Old 09-04-2018, 02:47 PM   #9
moshe1436's Avatar
I like that reference "stick and tin" -- sometimes I think it's exactly that! Several years ago there were only a few companies that used aluminum sidewall construction but I guess that has expanded to many more. I had always said if I ever wanted an RV I would buy one with lightweight aluminum construction. Well, here it is many years later and that idea went right out the window! It is what it is, and I am living with my decision, which I don't think is really that bad - I like the unit so far. So knowing it has wood studs the stud finder might work inside the unit or maybe even on the outside if I'm lucky.
Mo and Jeanette
Old 09-12-2018, 10:17 AM   #10
moshe1436's Avatar
According to a Forest River Specs Sheet my 241QBXL has aluminum body construction and sheet metal sidewall construction. See copy of specs sheet under "construction".
"Bikendan" where are you getting your info on wall construction from?
Name:	241QBXL Cruise-Lite Specs.jpg
Mo and Jeanette
Old 09-12-2018, 03:54 PM   #11
bikendan's Avatar
https://www.roamingtimes.com/rvrepor...struction.html
Equalizer WDH
