Old 11-12-2014, 07:28 PM   #1
Water drainage from air conditioning
We did our walk through this morning.
At the end, we noticed that quite a bit of water was coming out of a drain under the bottom of the unit......water from the air conditioning we're assuming. Is this normal? If so, how do you direct the water away from you so that it doesn't soak everything around you?
We didn't completely finish today because they had not added any propane to the tanks so we couldn't test those items that utilize it.....and the box was there, but the grill that came with the trailer was missing.
Also, just how loud should the fan on the air conditioner be? It seemed quite loud to my husband....
Parmela is offline   Reply With Quote
Old 11-12-2014, 08:01 PM   #2
KDHfan's Avatar
I'm no expert, but I don't believe water from your a/c should be running under your camper. Typically, I believe it just runs off the roof. I'd certainly follow up on that.
As far as the loudness of the A/C... our new camper has a Dometic, and it is noticeably louder than our previous Coleman-Mach
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 11-12-2014, 08:08 PM   #3
raspivey's Avatar
Did you check the water while doing the walkthrough? It's fairly common to just leave the gray tank dump valves open. If that's the case, it was probably any water from the sinks running straight out on the ground.
drain, water, air conditioner
