Originally Posted by HoundsAbounds
We are having the same problem. We are getting propane but no spark. It worked all morning, and then quite and will not relight.
Have you made sure you have propane, and possibly turned off/on again the inside DSI switch in case you were in lockout mode?
Is the water inside the tank cold? I know this is a weird question, but just making sure the water temp needs to be heated, as the dsi won't come on if the water is already hot.
