Old 08-10-2015, 09:46 PM   #1
Tfort's Avatar
Water leak from the front air conditioner
So we left our site for a bit and while we were gone an afternoon florida thunderstorm that dumped a lot of water in a short amount of time came through. We came back just as the storm ended and went to change close and found water running out of the return vent in the bedroom ac unit. Has anyone seen this? Oh it's a hemisphere 356 QBQ. It is still under warranty but I want to make sure it is not something I am ding wrong.
Tfort is offline   Reply With Quote
Old 08-10-2015, 11:28 PM   #2
Blog: RVroadtripper.com
hbillsmith's Avatar
I have exactly that same issue on my 2016 Wildcat. The storm was hellatious but the water drip was coming down the right side return air vent. It was a tiny drip that only amounted to about 8 oz. For the night. I used a hair dryer on the carpet next morn. It happened again on the second storm. This time I put a bowl on the floor to collect the drip. Still only 3 or 4 ounces. Plan to have it looked at this winter when I drop for warranty work. I hope it's just a bent or crimped gasket.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 08-11-2015, 01:37 PM   #3
Tfort's Avatar
Ok so it did it again today but not quite as bad but this time not a drop in the sky. I guess it is condensation that is running back in. I am going to take the cover off and see if something is clogged or needs sealed correctly.
air conditioner, leak, water, water leak
