Old 04-20-2015, 09:10 PM   #1
Golfnbike13's Avatar
Water leak through antenna?
We had pretty hard thunderstorms last night. The wife said she went in the TT this morning and there was a very small puddle in the floor with a water droplet hanging off the antenna crank in the ceiling. We have the 195bh model from 2014.
When I got home this evening I checked and couldn't find any sign of water damage or issues around the antenna. But I went ahead and put another beed of the rubber roof repair stuff around it.
Has anyone had this problem? Is it possible to leak through the antenna?
Golfnbike13 is offline   Reply With Quote
Old 04-21-2015, 05:42 AM   #2
indybp57's Avatar
I had a leak around the antenna cable that was puddling in my cabinet. Found a void where the cable went through the roof that didn't get sealed. Lap sealant took care of it. I've never studied the cranking mechanism but am guessing there is an o-ring or similar that is supposed to seal off the crank rod?
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 04-21-2015, 06:09 AM   #3
Canadian Member
Try this video on Winguard RV TV Antenna Maintenance. It might help you at least understand how it works and how it seals.
http://youtu.be/KATPS5bU0nY
2019 Rockwood Signature 8290BS
Old 04-21-2015, 02:03 PM   #4
Great, thanks!
Old 04-21-2015, 02:18 PM   #5
Flybob's Avatar
On some of the Wingard antennas there is a rubber boot around the ant cable where it goes into the roof mount. That boot has a tendency to slide up the cable breaking the seal. You can put a small amount of sealer around the bottom of the boot to hold it in place.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-22-2015, 05:08 PM   #6
X2. Know what you're saying. The boot is about the size of a thimble.
SkipnTerri is offline   Reply With Quote
Old 04-22-2015, 06:34 PM   #7
jeff64's Avatar
[QqUOTE=Golfnbike13;841341]We had pretty hard thunderstorms last night. The wife said she went in the TT this morning and there was a very small puddle in the floor with a water droplet hanging off the antenna crank in the ceiling. We have the 195bh model from 2014.
Has anyone had this problem? Is it possible to leak through the antenna?[/QUOTE]
Seen that before with winegARD ant. You'll have to disassemble. It's the o ring. Replace and give it a coat of silicone o ring grease use on water filter o rings too
Old 04-23-2015, 09:44 AM   #8
Send a message via MSN to redjet
It should still be under warranty - let the dealer fix it. Other solution is buy the kit that replaces the seals. Must disconnect the antenna arms but instructions are pretty easy to follow. Most of the work is from the roof side. I know - been there - done that.
redjet is offline   Reply With Quote
antenna, leak, water, water leak
