Old 10-01-2010, 08:50 AM   #1
water supply leak
i bought a 2004 26 'salem 1 owner with soft spot in bedroom floor above waterlines,,found under center draining tub weeping at cold water tee ,access hole is in place for end drain so hard to work on so bought new access panel to make another hole ,have found when maufactured center drain puts waterline in bind and caused the leak from when new ,the owner never noticed it ,also the havent used in 2 years was wondering if a common problem from forest river
voggie is offline   Reply With Quote
Old 10-01-2010, 08:32 PM   #2
milzat's Avatar
Originally Posted by voggie View Post
i bought a 2004 26 'salem 1 owner with soft spot in bedroom floor above waterlines,,found under center draining tub weeping at cold water tee ,access hole is in place for end drain so hard to work on so bought new access panel to make another hole ,have found when maufactured center drain puts waterline in bind and caused the leak from when new ,the owner never noticed it ,also the haven't used in 2 years was wondering if a common problem from forest river
Haven't had that problem on my last two FR products. So, I'd have to say I wouldn't think it's a common problem.
BTW, Welcome to FRF. Enjoy the forums and
milzat is offline   Reply With Quote
Old 10-01-2010, 10:08 PM   #3
ok thanks ,the guy i bought it from wasnt too mechancal i dont thinki figured it out quik ,the problem was access cover i wrong end of tub for fittings
Old 10-15-2010, 01:59 PM   #4
All I have is problems with the water system in my FR. After three years, this thing is still destroying itself.
'99 F350 Crew Cab 4x4 Lariat Off-Road V10
Vortech supercharged with aftercooler, 4" Pro-comp, 35" Nitto Terra-grapplers, Headers, Flowmaster cat-back, March underdrives, Diablosport predator tuner.
'07 Salem T26BH
If you want to buy one of these just take the cash, wad it up and throw it into the garbage.
eightrac is offline   Reply With Quote
salem
