Old 09-12-2019, 09:21 AM   #1
Tabasco's Avatar
Wet underbelly
My son accidentally left the shower water faucet on ever so slightly but enough to fill the tank overnight thus flooding the RV. Most of the water made its way to the underbelly. I poked several holes through the underbelly so it would drain. My question is, do I now need to drop my underbelly to dry out?
2015 Toyota Tundra 4x4 TRD with 5.7L
2016 Forest River 27RKSS 30ft.
Tabasco is offline   Reply With Quote
Old 09-12-2019, 09:46 AM   #2
If there is Insulation under there, it's gonna take a lot of air to dry it out, so dropping the underbelly cover is probably in order. Unless someone has better ideas.
TheWolfPaq82 is offline   Reply With Quote
Old 09-12-2019, 09:47 AM   #3
SeaDog's Avatar
If you had that much water I would advise you to drop the corpolast (in the area that you drained) remove any soaked insulation (if you have it) and check the heater ducts for water good luck.
Retired Navy
2016 Flagstaff 26 FKWS
underbelly
