Old 05-04-2014, 09:18 PM   #1
What Bearings....?
Anyone knows what berings are being used in the Salem trailers? 2012 26rks here.
Kuba is offline   Reply With Quote
Old 05-04-2014, 09:21 PM   #2
TURBS's Avatar
It's unlikely anyone will know what bearings are in your trailer.
Why do you need to know?
TURBS
Sabre owners united!
Old 05-04-2014, 10:18 PM   #3
Spares?
Old 05-04-2014, 10:27 PM   #4
B47
TURBS
Perhaps I'm putting too much faith in FR material tracking here,but perhaps FR might have a record of what bearing manufacturer supplied the wheel bearing for that model on that date. Or perhaps the axle manufacturer might.
It's a stretch I know.
Old 05-04-2014, 10:37 PM   #5
Ret E-9 Anchor-clanker
donanddona's Avatar
Auto parts store told me the numbers are stamped on the edging of the bearings. Its the only way to be sure of what's there.
donanddona is offline   Reply With Quote
Old 05-04-2014, 11:17 PM   #6
Iggy's Avatar
The axles are probably made by Lippert not Forest River.
If you really need to know you will have to remove one and get the numbers on the outer shell.
Iggy is online now   Reply With Quote
Old 05-04-2014, 11:24 PM   #7
B47
Right - that's why I said "Or perhaps the axle manufacture."
My reference to FR was to suggest they might have records of what Lippert was using as their bearing supplier for that model and date.
Old 05-05-2014, 06:58 PM   #8
H2oski
Cross check your axle manual (manufacture/size, Lippert/ 3000lb) then lookup the bearings and races, get the numbers and ID/OD sizes at the manufactures web site then go to NAPA or Car Quest and give them that info and they will be able to give you a set of bearings and races.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 05-05-2014, 07:36 PM   #9
Will do! Thanks a bunch guys!!
Old 05-05-2014, 08:32 PM   #10
Be sure to secure a (Grease Seal) & cotter pin as well! Youroo!!
youroo is online now   Reply With Quote
bearings
