Old 08-15-2014, 08:59 AM   #31
Take a picture of it with the vent cover open and we will tell you for sure its gas, but might not be electric. Or simply post the model number here.
Kuba is offline   Reply With Quote
Old 08-15-2014, 09:13 AM   #32
Originally Posted by Golfnbike13 View Post
If I have to use an extension cord to plug trailer in to power do I need some type waterproof cover for the cords connected ?
We use a (Plastic gallon throw away jug) slit top to bottom,on (1) side.Hole cut in the bottom for cord size.Place connected area inside jug. Cost$-O! Youroo!!
youroo is online now   Reply With Quote
Old 08-15-2014, 11:20 AM   #33
Golfnbike13's Avatar
Model Suburban SW6 D
Name:	ImageUploadedByForest River Forums1408119632.755168.jpg
ID:	60578Click image for larger version
Name:	ImageUploadedByForest River Forums1408119643.007920.jpg
Golfnbike13 is offline   Reply With Quote
Old 08-15-2014, 11:22 AM   #34
TURBS's Avatar
You have gas only.
But I think you can add an electric element to it.
TURBS
"SABRE OWNERS UNITED"
Old 08-15-2014, 11:24 AM   #35
Then what are the two Push To Reset buttons? I know to fill the water heater with water before turning on, but if I'm hooked up to city water connection how do I do that?
Old 08-15-2014, 11:25 AM   #36
TURBS's Avatar
Limit switches.
One for at temp and one for over temp.
TURBS
Old 08-15-2014, 11:27 AM   #37
TURBS's Avatar
It would be a sw6de for electric.
You open the pressure relief valve on the water heater.
TURBS
Old 08-15-2014, 11:28 AM   #38
Kaadk's Avatar
To fill the tank, open the pressure relief valve (the tap at the top of the water heater). When water comes out, you're full.
You can also open a hot water tap inside, but I find the relief valve is easier.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 08-15-2014, 11:30 AM   #39
TURBS's Avatar
Not only that but if the water heater bypass valves are in winter mode you could turn on the hot water tap and get water but the tank won't be full.
IT'S ALWAYS best to use the relief valve.
TURBS
Old 08-15-2014, 11:17 PM   #40
Thanks for the help everyone. Enjoying our first night out now. But have a couple questions.
1. Do you leave the water heater on all the time or just when needing to shower?
2. Our TT has the window unit AC. While running it most of the day the air seemed to become lukewarm by nighttime. I'm assuming we ran it to much?
first time
