Old 04-25-2015, 04:27 PM   #11
Golfnbike13's Avatar
Thanks. I was actually just looking at the champion inverter 3100. Tractor supply has it for under 1k. Seems way cheaper then honda and very similar noise level. Anyone experienced these? http://m.tractorsupply.com/en/store/...carb-compliant
Golfnbike13 is offline   Reply With Quote
Old 04-25-2015, 04:35 PM   #12
acadianbob's Avatar
Originally Posted by HONDAMAN174 View Post
I'm thinking a 2000w should be fine. Just would not be able to run the AC and micro at same time. I have a Honda and love it but have been hearing that others have been getting a Champion 2000w and have had a good experience with it.
The AC on my trailer stops my Honda EU2000i dead in its tracks . . . .
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
acadianbob is online now   Reply With Quote
Old 04-25-2015, 04:52 PM   #13
Originally Posted by Golfnbike13 View Post
Thanks. I was actually just looking at the champion inverter 3100. Tractor supply has it for under 1k. Seems way cheaper then honda and very similar noise level. Anyone experienced these? Champion Power Equipmentâ„¢ 3,100W Gas-Powered Recoil Start Portable Inverter Generator, CARB Compliant - Tractor Supply Co.
Not a bad genny, sound level is 58db at 23 feet Yamaha 2000i is 51-61 @ 21ft. Think you would be happy with this one.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 04-25-2015, 04:57 PM   #14
Blackhat6mike's Avatar
The noise was not a problem with the Champion as we would put it 30 ft away from the Flyer, turn on the AC and close the windows. Very little noise. If you plan to have the gen right next to the unit AND leave the windows open, then noise probably will be a problem. I guess it just depends on if you want to spend an extra $1,000 or so to be quieter.
We don't carry a gen with us anymore since we went solar, but our two Champion 3500/4000 units are used around the farm and home.
I bought a 2000 Champion several years ago and did have several problems with it. I may have used too much Sea Foam in the fuel while stored as it ate the rubber fuel cock fitting just below the tank and started leaking. I replaced the fuel cock and all is well now, but still hard to crank. Champion has come a long way since I bought the 2000 model 7 or 8 years ago.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 04-25-2015, 08:21 PM   #15
67cudafb's Avatar
Check this out! Brand New Champion Power Equipment No 75531i Inverter Generator 3100 Watt | eBay
67cudafb is offline   Reply With Quote
Old 04-25-2015, 08:36 PM   #16
2015 2503S Mini Lite
Saberwolf 700's Avatar
Very good price there. Wish I would have waited to buy one now. Just bought the 2000w Champion a month ago for only $125 less than the 3100w one.
2015 Rockwood Mini Lite 2503s
2014 Ram 1500 Big Horn 5.7 Hemi
Saberwolf 700 is offline   Reply With Quote
Old 04-25-2015, 09:47 PM   #17
HONDAMAN174's Avatar
Mine too...but we are not running 8000 btu AC @7.4 amps like OP.
Just glad to get away
Old 04-25-2015, 09:56 PM   #18
B and B's Avatar
I was about to ask about the noise of the Champions. Seems like anything prices that cheap would be loud or inefficient?
Found this locally, would it be enough? Anyone know about this brand? Ryobi RYi2200 Inverter Generator
Where you live I would opt for a 3100, Air conditioner when running in the heat draw maximum current. The Ryobi is only 1800 watts, a 3100 is 2800 watts.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-25-2015, 10:07 PM   #19
dcheatwood's Avatar
Originally Posted by 67cudafb View Post
Wow! Great price. True signwave is good. 12 hr run time on 1.5 gals of gas at half load is unbelievable. Doesn't say here but amazon site says 58 decibels, which is good for non-honda/Yamaha.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 04-26-2015, 11:26 AM   #20
Rodney & Patty
I previously have had great luck with a Wen Power generator from Pep Boys. The 3500 was quite quiet, similar to the Honda, and had plenty of power to run our coach. It's only weakness was ethanol. .. forgot to treat it and let it set all winter...
Working because we have to - camping because we want to.
2015 Salem Hemishere 337 BAR
2014 Ram 3500SRW Laramie 6.7 I6
rdenslow is offline   Reply With Quote
generator
