Old 04-26-2015, 11:52 AM   #21
Blog: RVroadtripper.com
hbillsmith's Avatar
Champion 3100 inverter. Higly recommend, Have one for 2 years now. Buy at supergen.com for best price. If price not an issue, consider the model that has remote elec start for a couple hundres more. That one can be modded to add an extended run marine gas portable tank.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 04-26-2015, 12:46 PM   #22
bikendan's Avatar
Originally Posted by rdenslow View Post
I previously have had great luck with a Wen Power generator from Pep Boys. The 3500 was quite quiet, similar to the Honda, and had plenty of power to run our coach. It's only weakness was ethanol. .. forgot to treat it and let it set all winter...
As far as I know, that is an open-framed contractor generator that is nowhere as quiet as a Honda inverter generator.
It has no business in a campground.
it's fine for boondocking though.
Not sure what Honda you're comparing it with.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-26-2015, 08:30 PM   #23
67cudafb's Avatar
Originally Posted by 67cudafb View Post
Well I guess to good to be true! Tried to buy this item and won't let me
67cudafb is offline   Reply With Quote
Old 04-26-2015, 08:39 PM   #24
Only thing I can see is that won't ship to Canada, what problem are you having?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 04-27-2015, 12:25 PM   #25
Golfnbike13's Avatar
Could I run my AC (8,000 BTU) off the Honda 2000i? I'm confused because it doesn't have a 30amp plug in, so how would I hook up to the TT?
Golfnbike13 is offline   Reply With Quote
Old 04-27-2015, 02:33 PM   #26
bikendan's Avatar
You use the standard 30 to 20 amp puck adapter.
Old 04-27-2015, 07:04 PM   #27
67cudafb's Avatar
When I hit buy now or add to cart I get this. http://cart.payments.ebay.com/sc/add...17983632,qty:1
Old 04-27-2015, 07:20 PM   #28
When I hit buy now or add to cart I get this. Your eBay Shopping Cart
You have a e-bay account,correct? If you do double check your delivery address.
2014 Forester 3051s
2012 Sonic toad
Old 04-27-2015, 07:46 PM   #29
67cudafb's Avatar
Yep Just to be sure it wasn't trouble on my end add this one to basket no problem. Then removed no problem. Champion Power Equipment 2800 Running Watt Inverter Portable Model 75531i | eBay
Old 04-27-2015, 08:44 PM   #30
dcheatwood's Avatar
You can get the little 30 amp to 20 amp adapter at Walmart for about $5.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
generator
