04-26-2015, 11:52 AM
#21
Blog: RVroadtripper.com
Champion 3100 inverter. Higly recommend, Have one for 2 years now. Buy at supergen.com for best price. If price not an issue, consider the model that has remote elec start for a couple hundres more. That one can be modded to add an extended run marine gas portable tank.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
04-26-2015, 12:46 PM
#22
Originally Posted by rdenslow
I previously have had great luck with a Wen Power generator from Pep Boys. The 3500 was quite quiet, similar to the Honda, and had plenty of power to run our coach. It's only weakness was ethanol. .. forgot to treat it and let it set all winter...
As far as I know, that is an open-framed contractor generator that is nowhere as quiet as a Honda inverter generator.
It has no business in a campground.
it's fine for boondocking though.
Not sure what Honda you're comparing it with.
04-26-2015, 08:30 PM
#23
Originally Posted by 67cudafb
Well I guess to good to be true! Tried to buy this item and won't let me
04-26-2015, 08:39 PM
#24
Only thing I can see is that won't ship to Canada, what problem are you having?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
04-27-2015, 12:25 PM
#25
Could I run my AC (8,000 BTU) off the Honda 2000i? I'm confused because it doesn't have a 30amp plug in, so how would I hook up to the TT?
04-27-2015, 02:33 PM
#26
You use the standard 30 to 20 amp puck adapter.
04-27-2015, 07:04 PM
#27
When I hit buy now or add to cart I get this. http://cart.payments.ebay.com/sc/add...17983632,qty:1
04-27-2015, 07:20 PM
#28
You have a e-bay account,correct? If you do double check your delivery address.
2014 Forester 3051s
2012 Sonic toad
04-27-2015, 08:44 PM
#30
You can get the little 30 amp to 20 amp adapter at Walmart for about $5.
2018 Forester 3011 DS
04-27-2015, 09:21 PM
#31
That looks backwards. Shouldn't it be a 30 amp female and 20 amp male?
TT- '21 Spirit XTR 2146BHX
TV- '19 Nissan Titan XD Cummins Diesel 5.0
04-27-2015, 10:11 PM
#32
Absolutely correct. Thanks for catching that.
Op. It'll have basic 3 prongs for regular plug and will reciveo your rvplug on the back side.
Like this. Color does not matter.
04-27-2015, 10:45 PM
#33
A lot I've seen look just like that but say 30 amp to 15 amp. Is 20 and 15 the same plug?
04-28-2015, 02:45 PM
#34
Thats too bad cause its a good price on the Genny. Don't know to say to help you sorry!
2014 Forester 3051s
2012 Sonic toad
04-28-2015, 04:42 PM
#35
Yes. Sorry. 15 amp will do.
