Old 07-14-2013, 06:27 AM   #1
What is this light between my water pump and water heater switches?
I have this little red light right between my water pump and water heater switches. It reads "DSI FLT". Didn't see any thing about it in the manual. Does it have to do with the water pump or water heater? I think I seen it flash on for a short time last time I switched the water heater on. Maybe something to do with a filter? I'll try to post a pic!
2003 Chevy Silverado Crew Cab 1500HD 6.0 with a Whipple Super Charger
2013 Salem Hemisphere 312QBUD TT
stomperz71 is offline   Reply With Quote
Old 07-14-2013, 06:54 AM   #2
caper's Avatar
It should light when water first comes on when is gas mode. It is marked DSI.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 07-14-2013, 06:56 AM   #3
I believe it is the Direct Spark Ignition Fault Light for the water heater and will illuminate if the water heater fails to lite.
riversedge is offline   Reply With Quote
Old 07-14-2013, 06:59 AM   #4
Toad Haul's Avatar
My light comes on when I first turn on the WH. Once the heater ignites the light will go off. If it does not go off within a minute or so, I turn off the WH, wait a minute or so and re-try.
Darren, Donna & The Wieners
Toad Haul is offline   Reply With Quote
Old 07-14-2013, 07:09 AM   #5
Wanna Be Camper
SaskCampers's Avatar
x2
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 07-14-2013, 07:21 AM   #6
Denver, CO
garbonz's Avatar
Originally Posted by TheSasks View Post
x2
X3
2017 Fuse 23T
Old 07-14-2013, 07:23 AM   #7
Herk7769's Avatar
The DSI control board will allow 3 start attempts before lockout.
There is a 15 second propane flush before DSI spark. It will take time for the "Flame Rod" to detect the ignition. If it does all is well and the red light will go out. If not, the red light stays on and 6.8 seconds later and another flush/DSI cycle will start again. This will happen 3 times and can take about 2 minutes to complete all 3 attempts.
While "a minute or so" and 2 minutes sounds like "picking nits"; stand in front of that panel waiting for the light to go out with a stop watch.
It can seem like forever.
Nit-picking - Definition and More from the Free Merriam-Webster Dictionary
Definition provided for youngsters...
Name:	DSI Sequence.jpg
ID:	35296   Click image for larger version
Name:	DSI explained.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 07-14-2013, 07:48 AM   #8
Wanna Be Camper
As always, Nice answer Lou.
John & Deb
Old 07-14-2013, 08:23 AM   #9
B47
I was told it stands for "DSI.FAULT". The red light illuminates if the DSI does not ignite the WH gas after three attempts as previously mentioned.
Old 07-14-2013, 08:55 AM   #10
TURBS's Avatar
A good dealer should have told you this during pdi.
Old 07-14-2013, 08:59 AM   #11
Rugged Brown's Avatar
I timed mine at 6.69 secs.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 07-14-2013, 09:05 AM   #12
wmtire's Avatar
If the dealer didn't tell you about the DSI/propane option, he may have also omitted the part about the electric heating element portion of the water heater too (if equipped with an applicable type Suburban brand water heater).
This may help:
http://www.forestriverforums.com/for...ore-36197.html
2011 Flagstaff 831 RLBSS
Old 07-14-2013, 09:08 AM   #13
TURBS's Avatar
This may help:
Good point!
Or that they can be used together "gas and electric" for faster hot water recovery.
Old 07-14-2013, 09:08 AM   #14
Ah yes that makes it all clear. thanks for all the replys.
I was thinking the same thing f1100turbo, he kinda left me out on a few things that i'm slowing figuring out.
Old 07-14-2013, 09:30 AM   #15
wmtire's Avatar
The FAQ sections of these forums are a great place to start, in learning about many aspects of your travel trailer. It contains a wealth of information collected from the great members here.
Forest River FAQs - Forest River Forums
Old 07-14-2013, 09:38 AM   #16
I've picked up allot of good things from that section, thanks to all. Allot from my old 2007 Keystone TT has carried over to this new Salem, but theirs still allot that has changed over the years. Glad to be a member of this forum.
Old 07-14-2013, 09:42 AM   #17
Herk7769's Avatar
B-47,
That is true and some installations actually label the light "Fault"; but it is more than that. It lets you know that 12 volt power is going to the control board, the unit is calling for heat, and the flame has not started yet. It does not say "it won't"; just that it has not.
In fact, even with the water hot, that light will illuminate by itself when the water cools to the low point thermostat and calls for heat. Once the flame lights it will go out by itself.
Old 07-14-2013, 02:18 PM   #18
B47
B-47,
Ok - thanks for the additional information. I never look at it after the initial start up of the WH during the day so unless it happens to illuminate momentary and I see it after the initial start up I won't see it.
