Old 06-20-2014, 02:43 PM   #1
Where is tank Hemisphere 282rk
Trying to figure out where the water tank is located. In front of the axels, on top or is it behind. The reason I ask is when I got water in it i can tow fairly well but empty the front seems to bounce a said to adjust the wd hitch but not sure if I take off towards the front or to the rear...I hope I am making senese...thanks in advance.
mbaker5408 is offline   Reply With Quote
Old 06-20-2014, 03:00 PM   #2
Here. I just snapped a pic of where the overflow and drain lines are. Not knowing where the lines attach to the tank it is hard to pinpoint the exact location. But is safe to say it is very close to the axle.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2016: 33 nights camped; 5 nights booked
Teamfour is online now   Reply With Quote
Old 06-28-2014, 10:31 AM   #3
Boss Ox & Drovergirl
oxcamper's Avatar
The tanks are in front of the axles. The 2 hoses in teamfours picture are the overflow (not valve) is attached to the top of the fresh water tank and the low point drain (with valve) attached to the bottom of the fresh water tank. the weight of the 40 gal of water when the fresh tank is full equals approx 320 lbs. (water is 8.33 lbs/gal) On a 7000 lb trailer it isn't really that significant especially since it's near the axles.
I would suggest adjusting the WD hitch. I would try moving the hitch points toward the front
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
