Old 02-29-2016, 05:26 AM   #21
Oaklevel's Avatar
Just keep in mind you may run into legitimate tire dealers that will not install LT tires on your trailer. there are none in my area that will do it......
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 02-29-2016, 06:17 AM   #22
rattleNsmoke's Avatar
Cedar Creek has been installing LT's on most of their heavier trailers for years now.
rattleNsmoke is offline   Reply With Quote
Old 02-29-2016, 06:40 AM   #23
MilCop4523's Avatar
we did on our 2012 Salem. best decision ever. my original tires were toast in 2500 miles
we went with a KUMHO eurometric available at teh time and in 3 yrs saw very little if any wear.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 02-29-2016, 07:00 AM   #24
acadianbob's Avatar
Yes, those are great tires. Have them myself. 14" only though I think. LR D.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 02-29-2016, 07:20 AM   #25
f5moab's Avatar
Originally Posted by Taranwanderer View Post
Doesn't anyone use the search function... This topic has been beaten to death.
Here it is in a nutshell: if you "upgrade" to an LT tire, you're increasing speed rating (so you can, you know, drive 85 towing down the interstate,) but you're losing load carrying capacity (assuming you stay with the same overall size.) Now, you may be able to upgrade both your speed and load ratings if you go up in size (tire, rim, or both,) but not everyone has the room under their fenders to do that. So if you have to stick with an overall size, stick with ST for the load carrying capacity. IMHO. Good luck!
Yes, from my research you do have to go up in size to obtain the same load rating, or increase the load rating, of the factory size ST tire. Can't say that is true in larger tires, but those little lawn mower size 13" tires that came on my popup had a pretty good load rating. However, they did not hold up to rocks, boulders, etc.
f5moab is offline   Reply With Quote
Old 02-29-2016, 07:24 AM   #26
Speed Rating
Speaking of searches, there was a recent post that all trailer tires now have a higher speed rating. My Taskmasters from eTrailer are rated for 81 mph. I believe the 65 mph speed rating was a problem for all tires, no matter where they were made. The other issue is TT manufacturers using the minimum load rating tires for their trailers. I believe that with higher speed and load ratings, your tires will be more like the car tires you're used to.
mnoland30 is offline   Reply With Quote
Old 02-29-2016, 07:28 AM   #27
dieselguy's Avatar
I've had 4 new fivers in the #10K - #12K weight range since 2000 and have run LT's on them all. The 2000 and 2005 models came with LT's straight from the factory. I got rid of the Marabombs with haste on the last two. On the heavier fivers you just have to watch your weight ... you may have to go with G614's or equivalent.
dieselguy is offline   Reply With Quote
Old 02-29-2016, 12:57 PM   #28
Airdale's Avatar
Because the customs people put new tariff requirements on ST tires that also required them to put speed codes on them. It kind of forced them to raise the bar and go a little higher with the speed ratings. Because? There is no speed letter for 65 MPH. The TRA got on board and raised their maximum approved speed restriction for ST tires to 81 MPH. Bottom line? All new ST tires will have speed letters on their sidewalls.
A Trailer Tire Poster
http://www.irv2.com/photopost/showfull.php?photo=15339
Airdale is offline   Reply With Quote
Old 02-29-2016, 01:18 PM   #29
G614 Goodyear tires
I'm going with the Goodyear G614 tires, as long as my rims are rated for 110 psi, if not, I'll get new rims. $300+ for these tires!
Ultraboy is offline   Reply With Quote
Old 02-29-2016, 01:50 PM   #30
Fulltime family RVer
If you get new rims, make the jump up to 17.5" rims and tires. Huge jump in capacity and you'll be rolling on a heavy duty commercial tire.
led, tire, tires, trailer
