Old 09-06-2019, 03:49 PM   #1
Question Window leak test during hurricane
I have a 2016 SATW SALEM CRUISELITE 24' Model 241QBX. During Hurricane Dorian rain was hitting the dining table window pretty hard. Water started to come in near the top of the window. I opened the awning slightly which stopped the leak. Later I applied metal duct tape over the four rectangular slots above the window along the black frame. Are these drain slots? Are they supposed to leak? I'm going to seal them up.
Perry32935 is offline   Reply With Quote
Old 09-06-2019, 03:53 PM   #2
Yes they are drain holes. The window is installed upside down. Atleast that is what it looks like to me.
2019 ROO 233S
2017 Dodge Ram 1500 Laramie
Wisconsin-1 is offline   Reply With Quote
Old 09-06-2019, 04:13 PM   #3
It’s upside down compared to the windows on every rv we’ve owned.
2016 Berkshire XL 40A towing 2016 Jeep Wrangler.
Prior to this Jayco fifth wheel: 24' Eagle, 30' Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 09-06-2019, 04:14 PM   #4
Either that or the photo is inverted and the decals were applied upside down. I'm leaning towards your theory though.
I'm surprised water wasn't coming over the sill on the interior considering there are no weeps at the bottom.
woo10-210 is offline   Reply With Quote
Old 09-06-2019, 04:20 PM   #5
KyDan's Avatar
What he said!!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 09-06-2019, 04:50 PM   #6
Daycruiser's Avatar
Now there was a great PDI by the dealer!
44 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
Daycruiser is offline   Reply With Quote
Old 09-06-2019, 06:57 PM   #7
Not to mention the "genius" of whoever was in charge of quality control at the factory.
FWIW, even if window was installed correctly those "drains" can be a real pain. If there is enough wind along with the rain water can back up into the frame on the inside and overflow, ruining paneling.
My old 95 Terry had these drains on the front window behind a stone shield/awning. If I drove in the rain the shield would concentrate water and wind in front of the holes and when we stopped for the night the edge of the bed inside was soaked. Finally ended up just filling the holes with some Urethane Caulk and just mopped the condensation off the inside of the window and frame before it overflowed.
These drains need a "one way flap" on them although the OP's needs to have the window re-installed properly first.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 09-06-2019, 07:23 PM   #8
Some windows have weeps on top and bottom, so they can be installed either direction. Mine does, and has rubber plugs for the unneeded top weeps.
For the op, plugs can probably be obtained, or use black non leveling sealer. Could drill some small weeps in the bottom if needed (can't tell from the photo of there are weeps on the bottom as installed).
Dp26 is offline   Reply With Quote
Old 09-08-2019, 06:00 AM   #9
X2
lewisra is offline   Reply With Quote
Old 09-08-2019, 01:07 PM   #10
Dealer will most likely tell you.
"That is how they are installing them now."
That is in case you get a heavy up pouring rain.
Ok enough with the stupidity. Your window was installed upside down by the manufacturer. The dealer should have caught this it their nonexistent prep of you trailer before pickup.
Attachment 214350
campers302 is offline   Reply With Quote
leak, window
