Old 10-24-2014, 03:26 PM   #11
Boss Ox & Drovergirl
oxcamper's Avatar
Originally Posted by techntrek View Post
Not sure what you mean. All campers have a pump, but some don't have the winterization pickup line/valve.
You are correct, it doesn't have the ability for the pump to pick up the antifreeze. There is no open gravity inlet on the fresh tank on the 282 RK, so:
1. you need a pickup pump to put the afreeze into the fresh tank or
2. you need a length of garden hose with a funnel to pour the afreeze into the fresh holding tank,
3. or you need to use air to blow out the lines.
In any event, as was stated earlier, you need to add afreeze to the drain traps in the sinks and shower.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 10-24-2014, 04:15 PM   #12
Ok, I need a little help with mine. My fresh water pump came with the adapter and hose from the factory (very nice surprise). I drained the water and pulled the anode rod out of the hot water tank.then bypassed it. I ran the anti freeze to the water spouts (hot and cold) in the bathroom, kitchen. Everything ran pink. Added some to the drains. Ran some through the city water inlet with a adapter hand pump device I bought. Prior to all this I drained the water from the low point drains and the fresh water tank. Do I need to add antifreeze to the fresh water tank and run through the pump also? Thanks
whitmw is offline   Reply With Quote
Old 10-24-2014, 08:47 PM   #13
Sounds like if you used fresh pump and pick up hose to get the antifreeze through the lines you should have gotten it all taken care of....at least it sounds that way to me....
mbaker5408 is offline   Reply With Quote
Old 10-25-2014, 01:40 AM   #14
Did you check the outside shower for antifreeze? (if your unit has one).
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 10-25-2014, 06:25 AM   #15
No outside shower, but I plan on putting one in as soon as the warranty runs out. The only thing I was concerned about was the lines that run from the fresh water tank to the pump. Does that drain out when you drain the fresh water tank? Thanks
Old 10-26-2014, 07:30 PM   #16
4. You add the winterization valve on the pickup line just before the water pump.
5. You temporarily remove the pickup line at the water pump and add a 3-foot section of hose which you then use to suck up the antifreeze.
Adding antifreeze to the water tank has issues - primarily dilution due to the remaining water in the tank. Only using air to blow out the lines is also a bad idea, you will eventually have damage.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 10-26-2014, 07:32 PM   #17
Yes. And the little bit of water left in the water tank won't cause a problem since it has room to expand when it expands.
2010 Chevy Suburban
Old 11-08-2014, 02:07 PM   #18
Where are the low point drain lines at on the 282rk model, I can not find mine please?
Eddy G is offline   Reply With Quote
Old 11-12-2014, 11:33 AM   #19
How many gallons of RV antifreeze should I buy for a 282rk? Has outdoor kit and outdoor shower.
Eltonnoland is offline   Reply With Quote
Old 11-13-2014, 08:17 AM   #20
oxcamper's Avatar
Your low point drain is hanging down directly behind the right side wheels, by the entry door.
you can access by lying on the ground and going between the front and rear wheel. The drain has a 1/4 turn petcock, the other tube is the fresh water overflow.
winter, winterize
