Old 11-13-2014, 07:20 AM   #21
Boss Ox & Drovergirl
oxcamper's Avatar
Originally Posted by Eltonnoland View Post
How many gallons of RV antifreeze should I buy for a 282rk? Has outdoor kit and outdoor shower.
I don't have an outdoor kitchen or shower (opted out of them). So, just for the galley and bathroom I used a little over 4 gallons. We don't use our fresh tank or pump but I ran an additional gallon into the fresh tank and recirculated with the pump just in case. If you have the shower and outside sink, I would guestimate 6 gal, 7 to be safe it's not that much $$.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 11-13-2014, 07:23 AM   #22
oxcamper's Avatar
PS Make sure you drain the water heater and put it in bypass before putting any A-freeze into the system.
Old 11-13-2014, 07:24 AM   #23
To clarify - that "other tube" isn't a fresh water overflow, it is the fresh water tank vent line which should be routed up to the vent connection next to the fresh water tank fill spout. I don't know why FR insists on routing that line down instead of up on so many of their TT models. I fixed this on mine, now I don't lose 1/3 of the tank's contents going down the road!
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 11-13-2014, 09:54 PM   #24
Low point drain
Should I close this low point drian after draining, when pumping antifreeze in system for winterizing camper?
Eddy G is offline   Reply With Quote
Old 11-13-2014, 09:59 PM   #25
What size socket do I need to take the water heater drain plug out with please.
Old 11-14-2014, 05:27 AM   #26
Close the low point drains, but leave the fresh water tank drain open especially if you move the camper after winterizing it.
2010 Chevy Suburban
Old 11-14-2014, 05:33 AM   #27
Mine was 15/16"
Eltonnoland is offline   Reply With Quote
Old 11-14-2014, 05:42 AM   #28
Suburban water heaters the anode rod is 1 1/16".
2010 Chevy Suburban
Old 11-14-2014, 10:33 AM   #29
thanks so much.
Old 11-14-2014, 10:37 AM   #30
What are the 2 lines that come out underneath the trailer near the water heater? One is red and one is blue and both have screw on caps.
winter, winterize
