Old 11-11-2014, 06:49 PM   #1
McCubbies
McCubbies's Avatar
Winterizing issue
First time winterizing. Current temps in MO. Yesterday 72, today 35. Not a typo here is the steps I took.
Drained hot water tank. Put RV antifreeze in freshwater tank. Turned on pump. Opened faucets one at a time until pink. Filled P Traps. Because I am compulsive, I checked the sink one more time and it started spitting air and then pink foam, and then some pink, then nothing. Bathroom sink and shower ran fine but the toilet also foamed and trickled pink. Scratching my head. Then went out and my grey valve wouldn't open (35 degrees). Opened city water connection, pulled the screen, pressed the valve and nothing came out.
Did I do something wrong here to cause air, foam?
McCubbies is offline   Reply With Quote
Old 11-11-2014, 06:51 PM   #2
fonzie's Avatar
did you close by-pass valves at water heater?
Fonzie
Old 11-11-2014, 06:55 PM   #3
davel1971's Avatar
as I'm reading this, thinking I just read this. Oh yeah, RV Tips and Helpful Hints on Facebook
David & Lynn
Old 11-11-2014, 07:05 PM   #4
McCubbies
McCubbies's Avatar
I did close valves and open bypass.
Old 11-11-2014, 07:15 PM   #5
caper's Avatar
You have drained all the liquid from the tank and now pumping air through the system.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 11-11-2014, 07:17 PM   #6
McCubbies
McCubbies's Avatar
That's a possibility. I put 5.5 gallons in the fresh water tank though. Was told it would be more than enough.
Old 11-11-2014, 07:17 PM   #7
jtstromsburg's Avatar
I would guess, since you used the fw tank method, you may need more antifreeze in the tank. Many of us either added or use the built in winterizing valve. It sucks AF from the bottles and pumps it right into the lines, avoiding the fw tank. With my lines full of AF, I pushed the check valve piece on the fw hookup like you did, and got nothing as well. Hoping it's fine come spring.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 11-11-2014, 07:20 PM   #8
You don't want to put antifreeze into the fresh water tank. The biggest reason is you won't get all of the water out, so you end up diluting the antifreeze before it is even in the water lines, then it gets more diluted as it meets the pockets of water in the lines and valves.
Find the water pump and remove the intake line coming from the fresh water tank, and add a temporary 3-4 foot hose. Draw the antifreeze from the gallon jugs of antifreeze, undiluted.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 11-11-2014, 07:23 PM   #9
WFD
Most don't put antifreeze in the freshwater tank and simply siphon from the jug, provided you have the winterizing bypass valve at your pump. If not it's pretty simple to add one in next season. Now you have pink stuff sitting in your freshwater tank all winter and will have to flush it out next spring. Not that big a deal but an unnecessary step.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 11-11-2014, 07:28 PM   #10
WFD
When I pushed the plastic piece on the city water connection, like you, I did not get anything either. Then someone on here told me to leave the water pump on when doing it...bingo...then I got the big spray!
winter, winterize
