Old 07-06-2016, 05:27 PM   #1
Wireless Remote Problems
Hello, I am having Wireless remote problems with my 2017 Salem Hemisphere 272RL. Had it barely 2 weeks and now the wireless remote will only operate the awning lights, no slides, no awning and no stabilzers work except with the rocker switches. The remote is fully charged and so are the RV batteries. I checked the fuses and breakers and all seem OK. I do hear a slight clicking noise coming from under the bathroom linen closet when I try and use the remote. Anyone have any suggestions? Tried calling my Forest River dealer twice but got no response.
D-Man is offline   Reply With Quote
Old 07-07-2016, 09:14 AM   #2
Head Rambler
Go to the bathroom linen closet and operate the remote one item at the time. If you hear clicking at any remote function then you've found the receiver.
Remove whatever panel the receiver is hiding behind and check the fuses in the receiver. Those fuses are separate from the ones in the power panel.
If the fuses aren't blown then trace the power wires between the battery and the receiver for loose connections and/or blown inline fuses.
Gotta go campin!
Old 07-07-2016, 10:37 PM   #3
Thanks! I found the panel you were talking about and there were more fuses located back there. I found the blown fuse and now it's all set! Thanks again!
Old 07-08-2016, 07:27 AM   #4
Head Rambler
Thanks for coming back and letting us know that you found it and what the fix was. We appreciate feedback as to whether our suggestions help you fix a problem.
You didn't happen to notice if you had a 5 or 8 function receiver did you?
Gotta go campin!
