Old 12-14-2014, 09:24 PM   #11
Oaklevel's Avatar
Experiment & mix. Start with the scrap wood. The stain charts will only give you the roughest of idea of color. As has been mentioned different wood will turn up different color shades.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 12-14-2014, 10:13 PM   #12
I mixed two colors of Minwax Wiping Stain (almost like a gel, comes in a tube) to very closely match the Tuscan Maple on our cabinets. Make small batches and test on scraps of the wood you are using on your project.
Sirsea is offline   Reply With Quote
Old 12-15-2014, 07:20 AM   #13
RPAspey's Avatar
Originally Posted by donanddona View Post
Go light and you can darken by several coats. Go dark and you'll be sanding a lot!!!
X2...way easier to darken by restaining with same color, or tweaking color with another stain.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 12-15-2014, 08:04 AM   #14
mark0224's Avatar
Get a chart from minwax and get closest match. Then when applying the longer you leave it on the darker it will be . With stain apply it let set for a while and then wipe off and let dry. If not desired darkness do it again . The reason you wipe off is if you just paint on you can get areas that are dark and others that are light, this will make the stain even.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
