Old 07-19-2011, 05:56 PM   #1
Tiggern2's Avatar
Angry 24L 5th Dinette slide failed again!
We have a Sandpiper 24L 5th wheel with small dinette slide. When purchase unit in July 2008 the slide was noisy and then quit a year latter. Would not go out it just clicked when we used switch.
The local dealer took it in last fall and replace entire slide mechanism said it was faulty. We used it a few times in fall and all was well. Then we did not use it until a few weeks ago and same thing it just clicks. I can manually crank it a little and it works for a while and then when you need it out it just clicks. It runs smooth and straight when it works.
Can someone tell me if it is a adjustment needed or ?
Also is there a manual on line for this electric slide in our 24l?
Thanks Tiggern2.
Tiggern2 is offline   Reply With Quote
