Old 06-26-2013, 10:32 AM   #1
365SAQ Outside Kitchen
Have any of you found a potable ice maker that will fit under the microwave in this kitchen? Cab you tell me what you purchased?
Otherwise I have no clue on how often I will ever use the microwave they installed... has anyone removed it? Was it hard and finished behind there?
Thanks in advance for your help.
billmeje is offline   Reply With Quote
Old 06-27-2013, 07:36 AM   #2
Fulltime family RVer
Different camper here, but I wanted to get rid of my outside microwave. I may have even posted here about it. Long story short, doesn't seem to bad. Of all of the things for our 42' camper, I actually thought it was overkill to have a microwave outside.
I've had a complete change of heart, though. We actually use it on a pretty regular basis surprisingly.
ependydad is online now   Reply With Quote
Old 06-27-2013, 11:28 AM   #3
I bought one at Target that works great. You can sit it on the counter under the microwave in the outdoor kitchen. Just plug it in and add water. Think it was $100.
2011 2500 HD Duramax
2012 Sandpiper 365 SAQ
RandyLindsey is offline   Reply With Quote
Old 06-28-2013, 03:44 PM   #4
golfmedik's Avatar
We use our microwave in the outside kitchen constantly as we do 95% of our cooking outdoors. I do have a place to put an icemaker to the right of the sink and will probably end up putting it there. Under the microwave. Mine is a '12 so it may be a little different than yours.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 06-29-2013, 08:13 PM   #5
ehorn's Avatar
I also want to remove the microwave as we do all our cooking outside but never use the microwave. Ours has a tank monitor on the side of the cabinet, other then that looks like 4 screws holding the front panel on and really should be fairly easy after that.
2014 Sierra 365 SAQ
2014 F350 CC DRW lariat ultimate kodiak brown, 65 gallon titan fuel tank, bak flip box cover, many mods to come.
ehorn is offline   Reply With Quote
Old 12-08-2014, 07:31 PM   #6
How do you turn water on to sink outside. Thank you
Sent from my The Foys iPhone using Forest River Forums
360PDEK is offline   Reply With Quote
Old 12-13-2014, 01:10 PM   #7
Helmsey's Avatar
Check under the sink in the half bath, ours has 2 valves in there that control water to the outside kitchen faucet.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 12-15-2014, 01:50 AM   #8
jrobichaud's Avatar
What model year is tumor 365saq? In the half year model changes in 2014/2015 the kitchen cabinet design was changed. Mine is an early 2014 design which has the smaller fridge but higher under cabinet space. I have an Emerson ice maker that works great and fits behind the sink in the outside kitchen. I think I got it at target for $150. Works great. I've every 9 minutes.
jrobichaud is offline   Reply With Quote
