Old 04-11-2013, 10:26 AM   #171
golfmedik's Avatar
Originally Posted by Rufinit View Post
Thanks how big are each tank?
They are 54 gallons each.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 04-11-2013, 07:15 PM   #172
I am weighing mine tomorrow on the way to the dealer to have my slides adjusted.do I need to unhook from truck to have the rv weight
chiro is offline   Reply With Quote
Old 04-11-2013, 07:56 PM   #173
golfmedik's Avatar
Weigh the entire rig first. Then after you drop it off at the dealer, go back and weigh just the truck and then you can get the trailer weight and the pin weight from the numbers you have.
Old 04-13-2013, 07:53 AM   #174
rbcdp98's Avatar
I weighed mine without water. 21,600 total. 11,450 on the trailer axles. A little close to the 12,000 axle ratings. I may add 7k axles.
rbcdp98 is offline   Reply With Quote
Old 04-13-2013, 09:32 PM   #175
I weighed mine full of lpg and 1 Battery. I'm within dodges axle ratings. I don't like that I lost 80 lbs on the front axle once loaded.
Name:	2013-04-13 10.36.03.jpg
2013 365 SAQ
Rufinit is offline   Reply With Quote
Old 04-13-2013, 10:56 PM   #176
Fulltime family RVer
What truck do you have? You're weighing in quite a bit less than me (ready to camp, our truck alone was 9,200).
My weighing...
weights
Old 04-14-2013, 11:40 AM   #177
rbcdp98's Avatar
I pull with a ram 2500 mega cab diesel. The truck weights 8200.
Old 04-14-2013, 03:01 PM   #178
2006 Dodge Mega Cab 5.9 This was just with me but full of fuel. I had just picked up the camper from RVW.
I only had 30lbs in the air bags. I may goto 40lbs and see if that gives me back the factory rake to my truck and add a little weight to the front axle.
Name:	2013-04-11 13.01.35.jpg
2013 365 SAQ
Old 04-14-2013, 03:46 PM   #179
What's your truck's GVWR?
Old 04-19-2013, 11:16 AM   #180
supercab79's Avatar
Monty here's a pic of the air bags. Finally just a few free minutes to put them in. I also threw a set of bilstein shocks on while I was under there. I'm anxious to see if there's a difference.
Marc
06 3500 Laramie Dodge Mega Cab 4x4 5.9CTD Short Bed Dually
13 Sandpiper 365SAQ Fifth Wheel
05 Chevrolet Tahoe
93 F-250 XLT 4x4 Diesel Banks Sidewinder (gone but not forgotten)
79 Jeep CJ-7
77 F-250 Crew Cab Short Bed 4x4
supercab79 is offline   Reply With Quote
365, 365saq
