Old 07-03-2015, 10:17 PM   #211
Golf and Aqua, I know this was brought up a while ago. Last August they put the new 7 k axles under my 365. My main AC went up in July with a couple of days left on my warranty (which they covered). The AC and axles were replaced at the same time. The AC unit that came with the camper is no longer made authority of the manufacturer and they sent a replacement. My new height is 13' 10''. What is yours. Just a little paranoid now when pulling. Have taken multiple sewer vent caps off in last two trips out.
2008 Sierra Crew Cab LB 4x4 Duramax/Allison
2013 Sierra 365SAQ
Nights camping in 2014: 25
rwpdir is offline   Reply With Quote
Old 07-04-2015, 07:15 AM   #212
AquaMan's Avatar
I'm around 13'5" at the front ac, which is a full size unit. What kind of ac did they put on yours?
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 07-04-2015, 07:15 AM   #213
golfmedik's Avatar
Mine was 13'2" a while back when measured. The new axles raised it some as well as the GY tires. My 365 has the big AC units too. Not even the low profile one in the front bedroom. I've already replaced the front AC shroud as I punched a huge hole in it last summer. I hit the dang thing again this past week, but only scuffed it up. I would like to see just how mine is measuring up now, but I look around and I see others that HAVE to be higher than mine.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 07-04-2015, 07:38 AM   #214
AC units are Dometic. Front is low profile. Old main was more rectangular and same height as front. New one is square and now obviously higher than front. Forgot, when the new Axels were installed I went to Firestone Transforce HT's rather then the China bombs. Also went up half a size which added some height. I used to be 13'2''. Big difference with the three modifications.
2013 Sierra 365SAQ
Old 07-04-2015, 04:11 PM   #215
So is there an email address at forest river for someone that will actually reply or is it better to call them
No breaks on a 13000#+ unit is far from acceptable along with the fact of the minimal CCC.
Faulk222 is offline   Reply With Quote
Old 07-07-2015, 10:07 AM   #216
Well finely got an answer from FR
The 6000lb axles were standard when yourunit was built. When we switched axles brands the 7000 were cheaper than the6000 so we made the change from ALKO 6000 to Dexter 7000. Your dry weightmay be 12600 but you need to deduct the hitch weight and your axles are notunder rated."
they don't seem to think that there is an issue with the axles anymore I guess will be looking into this a bit more looks like a generic reply to see if I will just let it go to me
Old 07-07-2015, 03:54 PM   #217
golfmedik's Avatar
Read back through the forum post. As of 2008, federal law prohibits them from deducting the pin weight. And they know this and try it with everyone. Under the FMVSS...
Old 07-07-2015, 06:39 PM   #218
i have read through the sandpiper and sierra threads and there are some great info there only issue is that i am in canada and am searching for some similar regs up this way which i am sure that there are
Old 07-11-2015, 03:22 PM   #219
Just an update for Canadian owners forest river is ignoring the issue for me not replying any more to my emails
I have contacted transport Canada for specific laws along with the safety complaint department about undersized axles on this unit
I suggest any Canadians that have this issue also contact transport Canada and make them aware as I do not believe that 12000# axles are sufficient to stop these RV in a sudden stop situation and is really a safety issue with my 3 kids on board of a 14000#+ trailer
I have referred them to the NTSB rulings of 2008 having to use axles taking the full weight of the trailer
When I get any updates I will post them here
Old 08-11-2015, 04:45 PM   #220
AquaMan's Avatar
I'm curious as to what the ruling actually says. Could you point me to the actual paragraph, so I don't have to read the entire thing?
365, 365saq
