03-17-2013, 07:37 AM
#141
I'm more confused by the axle and dry pin calculation now...IMHO it should be max pin weight + max axle weight = gvwr because just adding the dry pin leaves you an undistributed weight of contents
2012 Ford F-350 6.7L CC SRW w/FX4
2013 Forest River Sierra 365SAQ
03-17-2013, 08:15 AM
#142
How they derived the GVWR of the camper was as Dave stated, they take the 2 6K axles and then the dry pin weight of 2060 pounds. I agree it should be max weight for the pin, but that isn't how it's done. You are absolutely correct. Dry pin weight really means nothing to us, other than trying to figure out what truck to buy(or if the one we have is adequate), since we are going to load the unit. Ideally the pin weight should be within 15-25% of the weight of the camper. Some people will have more on the pin due to the way it is loaded. There are people who weight their rigs, then go back and try to distribute the weight more evenly. Most of these do this in motor homes to try and even out the suspension. It's called "4 corner weighing". However it really doesn't matter to us in 5ers as we have 4(or 6) wheels on the ground then the pin weight. Some try to add or subtract from the pin in ours. After my axles were changed, I now have a GVWR of 15,500 which is the rated limit for my pin box.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
03-17-2013, 08:32 AM
#143
Wow, dry pin should have no bearing on total, I think gvwr would equal axles plus 25% pin rating which off the top of my head should estimate out to about a gvwr of 15k
03-17-2013, 08:37 AM
#144
Agreed!
03-17-2013, 08:51 AM
#145
I'm not stupid to make my rig weigh 20k lbs but I have personally accepted the calculated risk of being under 15k based on the "conservative" manufacturer numbers. When I weigh, if the only number I'm over is the gvwr, I'm content as long as its minimal
03-17-2013, 10:43 AM
#146
No one considers the fact the frames are only built to carry x amount. Maybe that is why they have 6 k axles.
03-17-2013, 10:51 AM
#147
Very true, however; with that being said, a 7k axle option wouldn't work and not be available if the frame couldn't support it. I agree frame might be a factor but I believe the frame is probably the highest rated weight item in the rigs as most frames are the same and only difference is length regardless of most makes or models
03-17-2013, 10:56 AM
#148
Also there is no such thing as a short bed dually, they all have 8 ft beds thus they would not need to put rounded caps to fit a SRW short bed making it more of a marketing and sales calculation than safety. Golfmedik opinion rings true, business 101 says if you want to sell a product, make it marketable to a vast majority rather than a select group. With the lower ratings it makes it appear good for short bed 250's and 2500s
03-17-2013, 12:24 PM
#149
I'm heading out next week for FL, and will stop along the way and get mine weighed. Curious as to how it will weigh out, fully loaded for a week, and only minimal water in tank.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
03-17-2013, 02:15 PM
#150
Beausdog just a clarification there are short bed duallies the Dodge Mega cab like mine is a 6.5 ft bed and Ford also offered a crew cab 6.5 ft bed dually from 02 to 07. The fords are rare I looked long and hard for a 7.3 liter 02 early 03 short bed to no avail so it was the Dodge instead.
This post is taking on a life of its own.
However, on another note back to the dealer this week for the punch list. Both ac units have bent fan shafts and are shaking the rv down through the walls and floor, and the roof is having some weird rust staining coming up through the impervious rubber roof this looks concerning to me since it looks like there is a water or dampness issue under the roof. By the way it was built in November and we haven't used it once yet so i can't imagine where the water or moisture is coming from. Also right were the rust marks are are above the bathroom and the ceiling is now sagging and the ac vent hits the top of the door which it didn't do a month ago, add in the slide issues and non latching doors and we shall see.
Short Bed Dually
06 3500 Laramie Dodge Mega Cab 4x4 5.9CTD Short Bed Dually
13 Sandpiper 365SAQ Fifth Wheel
05 Chevrolet Tahoe
93 F-250 XLT 4x4 Diesel Banks Sidewinder (gone but not forgotten)
79 Jeep CJ-7
77 F-250 Crew Cab Short Bed 4x4
03-17-2013, 02:20 PM
#151
Short Bed Dually
Well I stand corrected, so I shall rephrase, they are extremely uncommon and thus would not be intended change for a short bed dually
03-17-2013, 02:22 PM
#152
Oh and since I have to throw a dig every now and again.....it's a dodge....doesn't count hahahahaha
03-17-2013, 03:38 PM
#153
Now that's funny I know. I was a life long Ford fanatic
05 Chevrolet Tahoe
79 Jeep CJ-7
03-17-2013, 03:43 PM
#154
But the 6.0 cured me quickly of that
A good friend of mine told me the best joke about driving a Dodge. I use it whenever I can.
Driving a Dodge is like making out with and ugly girl it's not bad when your alone doing it you just don't want anyone you know to see you doing it.
Wow it's not as funny when you have to clean it up for public viewing but use your imagination.
Marc
05 Chevrolet Tahoe
79 Jeep CJ-7
03-17-2013, 04:49 PM
#155
Mark, sorry to hear about your issues. I hope it comes to a quick fix as warmer weather is just around the corner and I want you to experience how great these rigs are! As for mine after the axle swap, I have been having problem getting the trailer to stop. The OEM axles had 'Never Adjust' brakes, the new ones do not. So today I jacked up the rig to adjust them manually. I was shocked. Realistically I only had one brake stopping the unit and it was the right front! The others were drastically out of adjustment,. Now all is good. Can't wait for the camping trip this weekend to try them out!
Marc, let us know the outcome and good luck!
03-18-2013, 09:11 AM
#156
I Have a 2013 365 SAQ (Bought in Apr. 2012) W/2 nd A/C, & Generator, Weighs 14,800, with approx. 3000# Hitch Weight. She pulls well, But I Know She's Back there in W/VA.
03-18-2013, 09:36 AM
#157
What are you pulling it with?
04-01-2013, 08:28 PM
#158
Just brought our rig to the scales. 07 2500 megacab 6.7 cummins with air bags. 2013 365saq total weight 21,600 rear axle weight of 5420 and front axle weight of 4860. The trailer axles were 11,320, this is a little close to the 6000 lb axles then I like. This was with 50 gallons of water onboard . we usually do not carry water
04-06-2013, 11:46 AM
#159
Hey Golf and others.
I read through the entire thread again and have not found the total outcome of some of these issues. I do understand some are not resolved yet.
Golf did they infact send you a new weight sticker? If so can you post a photo? I don't have a 365 but I do have a Crusader 355BHQ and it's about the same layout as the 365 and my sticker is wrong as well and I am in the process fo trying to get a resolution.
My trailer is rated at 6k axles but they are 8 lug so I know that at least the axles are 7k but I can not confirm the springs or hangers. I am suposed to have 2043lbs of cargo but I only have 1300lbs, and that is from empty.
I have 3 kids and my wife and I, so I know we will be over that just with our "stuff" and that will not include water. Alot of CG's in Colorado are "Dry" so you need to bring water.
This is quite frustrating because if you are in an injury accident insurance will defenetly deny your claim if infact you are over weight even by 10lbs.
This is really just sad. I can not belive that FR is letting these things roll out of the plant with these numbers.
They may have handled the situation but have created a much bigger one by letting the unknowing people to find out after the fact and then telling them "Sorry it is out of warranty"
Sorry for the rant in your guy's thread.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
04-06-2013, 06:03 PM
#160
Yes, they did send me a new sticker and sorry, I thought I did post it but apparently I must have dreamed I did!
Here they are right after I got them installed. One of my camping buddies ordered a new triple axle toy hauler and when it came in it had 6k stickers for the axles and 3 7k axles under it with the wrong weights. He caught it before he left the dealer and the dealer called FR right then. Still took him over 3 weeks to get a resolution with the appropriate stickers.
Crawl under your camper and look at the axles somewhere around the center, it should have it stamped on them what weight they are and the diameter of the tube. I would take a pic of that to start with and then go from there.
There have been several that have contacted myself, or a couple of others that have posted in this thread, about their axles and weights as well. I still do not understand how they think a rig of this length can operate safely on 6k axles. Most all other units I look at, and I look at every dealership around me, I see 7k axles under most every rig over 36-38 feet and these are over 40! Drives me nuts!!!!
