Old 05-11-2014, 09:14 PM   #1
SouthAlabama5er's Avatar
376BHOK outside speakers
I was wonder if any one had thought about running speaker wires from the outside speakers back the outside kitchen to mount a speaker underneath the cabins over the sink? I like having some tunes while I'm outside cookin but I dont wanna cranking it up too loud to hear it around the slide.
2008 F-450 Lariat 4x4 6.4 Power Stroke
2014 Sandpiper 376 BHOK FW
B&W Turnover Ball w/ Companion™
SouthAlabama5er is offline   Reply With Quote
Old 05-20-2014, 06:58 AM   #2
Our 360pdek has speakers in the outdoor kitchen along with the ones up front..it's nice...and yes you can tie into the stero which is right behind the kitchen
Tm_rich is offline   Reply With Quote
Old 05-27-2014, 08:06 PM   #3
My trailer is on order and I just tried to call today to add the speaker in the outdoor kitchen. The salesman told me they factory was to far along to add the speaker. So I guess I will do it my self. Where are the speakers located anyway? The salesman told me there was a total of six outside.
Dooley is offline   Reply With Quote
Old 05-27-2014, 10:50 PM   #4
Speakers
Our speakers are on the center of back wall above the sink
Old 07-18-2014, 02:50 PM   #5
BIGS
I want to do the same as well on our 376bhok, not sure where to get the access to the speakers though? There are only 2 speakers on the outside, 2 in the front bedroom, and 2 in the main living/kitchen area.
We just bought a bluetooth speaker for the outside, which i use while grilling and then also around the campfire at night. I noticed depending on where your campfire it and the 2 outside speakers, you may not hear it if the fire is towards the back of the camper. bluetooth speaker is great, and i just stream music from my phone.
Goofy thing on the 376 bhok - if your underneath storage doors are open, they cover the speakers. Sandpiper needs to raise the speakers and add some to the back outside kitchen.
acbigsby is offline   Reply With Quote
Old 07-18-2014, 10:32 PM   #6
I can reach the wires from the speakers through the propane compartment, and running the wires along the under carriage wouldnt seem hard. My question would be how to run the wires up to the outside kitchen?
Old 07-18-2014, 11:02 PM   #7
Plain Old Member
I always wondered what the longivity of those outdoor speakers would be. Knowing for a fact they're not high quality, what happens after being in the sun for years? So in our case, there's 2 - 5" holes in the side of the fifth wheel, with not much keeping water out of the wall. Just curious. I wish they weren't there. I'd rather them be mounted Inside the outdoor kitchen, or in the basement where they were out of the elements. Or better yet, just to NOT have more holes in the walls for potential leaks.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-19-2014, 08:43 AM   #8
BIGS
I thought of 2 options, bring them up behind the fridge, probably need to drill a hole through the countertop along the wall edge, not too big since it is one speaker wire and then run it into the cabinet with another drill hole and mount it in their.
The other option I thought of was to go through the bunk room closet and then out to the kitchen. You will need to take that bottom black cover off the undercarriage too to gain that access. You will have to seal it all back up once the project is completed.
After thinking of all of that, the $60 bluetooth speaker I bought seemed like a better option.
Old 07-19-2014, 08:45 AM   #9
BIGS
Probably will just have to buy replacements for them, some of the top manufactures make pretty top quality stuff for outside.
Old 07-19-2014, 12:10 PM   #10
Yea the blue tooth speaker sounds a little easier. Today I cut a half inch piece of plywood to raise up the outside fridge up, the door would hit the lip of the compartment and wouldnt open all the way. I unscrewed the legs as far a I could and it still hit. And I also mounted a paper towel holder on the back wall. Just taking care of little odd stuff, we leave Monday morning headed up to Gatlinburg for the week.
