Old 07-27-2015, 07:22 PM   #11
davel1971's Avatar
the wiring to your current 30 amp box will not work with a 50 amp. You need to start from scratch
David & Lynn
Old 07-27-2015, 07:33 PM   #12
elrand's Avatar
tell him a 2pole 50amp breaker and associated wiring
2015 Cedar Creek Silverback 33IK
elrand is offline   Reply With Quote
Old 07-27-2015, 07:54 PM   #13
fast murray's Avatar
You can make this as hard as you want with ways to explain this to your electrician but if you just tell him to install a nema 14-50R receptacle and wire it the only correct way to wire it you'll be fine. This is also the same receptacle that any typical 4 wire range will plug into.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
50 amp
